  • Replies 211
Posted Images
should organise a SAU-VIC drag day later on in the year...late spring/early summer....get some good track temps, but not too hot actual temps (dont want to have overheating issues ontop of gearbox troubles) :(
I also recorded my 2 best times after i handed in my times to ash....but I'm pretty sure pete has quickest RWD ET with his 12.8 for sure, my quickest was still 0.6 over that.
Definatly agree that the guy operating the tree wasn't very consistant with the time delay between staging and setting the tree going, I was revving for quite a while there on a few occasions, then other times I staged an less than a second after, the lights started falling....
hehe i asked the younger guy where the finish line was and he goes its his first day he doesnt no.. but somewhere at the end of the track...
The scrutinering was way more laid back than calder, that lady just made sure i had nothing in the boot.. :(
yeah i was expecting an engine bay check as well...even if it was just a quick 1....the guy didnt even look like he was gonna check my boot till i said, "do you wanna have a look?" after he asked if there was anything in there...lol
its obvious as anything can be. once you pass the xmas tree lines back off and you can begin slowing down. there are no other lines along the track so its theres nothing else it could be. i dont see where the confusion is or what else you were expecting?
pass the lines, the run is over. you should top out around 160km/ph when you pass this line in a mild R33 skyline
160km/h... yeah, right :worship:
And it was a fair call. The lines and markings aren't super clear for those who haven't done it before. There's no big sign or busty lass in a bikini waving a chequered flag for you. That said - one run makes it pretty obvious.
Very pleased everyone had a good time. The WRX guys share much the same sentiment, so I think another one MUST be done before the end of the year.
Team Lada will have some surprises ;):spank:
even my pass was complete at 98mph, just under 160km/h, so a real car with some power would be beating that ;)
and yes, 3 of these a year would be good....seems to be plenty of interest!
All photos have been uploaded to my server. I had to divide them into 15 parts as they are fairly large (250+ mb's in total). Total of 486 photos.
Links are:
http://www.allblitz.com.au/sau/sau-wrx10.zip
number 10 seems to be damaged Hus ...
I really dislike how the board at heatcote is before the finish line.
At calder, you see your time right after you finish. You dont have to do all this park, stop, collect, surprize time stuff :worship:
But yes, the 400m was where all the crap was painted on the road.
as if bass you will now want a low 12 or a 11 next time the drags are on hope to see you do it great job pete, im just happy that i got my 13 and did not stuff the clutch like i did last year
It was a great day. Thanks for organising it all Paul and Co. Not only was it a good from a driver view, it was just as fun from a spectator. The only gripe I have, is that Heathcote didn't let us continue with the BBQ, due to "Heath and Safety Reasons"…. The Ladies running the canteen weren't even wearing gloves, whilst handling my food!
Who was the other guy with the white 34 running slicks, no interior and no LH headlight? What times did he run?
At the end of the day, I was happy with my best time of 14.7 @ 94.6mph. Such a low terminal speed. I couldn't break over 95mph. So very happy to be in the mid 14's.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
