Buying A 32 Gtr
Hi,
In the next week or so i'm looking to buy a 32 gtr.
I know they're an awesome car and i also know they are aging but i haven't heard much about problems apart from the oil pump drive breaking. I'd be interested to hear any info from owners out there who have had any troubles.
Thanks in advance,
Stuart.
Ive had my 32 GTR for a few months and have replaced the ECU in it. Not too sure if thats a common problem with the 32's, but i know the Air Flow Meters are a fairly common problem. Engines are also getting old, and would probably be looking at a rebuild, especially if theyve been thrashed or driven uber hard in their liftime. Hopefully you find a car that the previous owner has already taken care of most of the problems the car may have had. This way you dont have to deal with many of them down the track. My knowledge with this vehicle is still very low sorry. Hope it helps though.
A dog is a dog, just cause its got a GTR badge on it dont think it cant be a lemon.
Engine/Turbo all you can do is check for excesive smoke from exhaust, check to see if timeing belt has been done, and if so the water/oil pump.
Driveline/Clutch check to see if clutch is holding up or slipping, change gears quite quick under load to see if syncros are ok.
Check brake disks for cracks.
One of my AFM's went in the first week.
Try and avoid 1989 GTR's if you can, most of the good ones are long gone.
A modified R32 costs about the same as a clean stock R33 , decide wehter you want the newer cleaner GTR or the modified faster one.
You can often get a FEEL for a cars state of health and condition by driveing it and giving it the once over, other than buying it from a dealer, thats about as good as it gets. GTR's with full service histories are rarer than a Honda Civic without a Mugen Power sticker... :D
Edited by mazgtr
 Share
    • Time for millspec wiring, MoTec electronics package, Bosch Motorsport ABS, let's goooooooo!!!   Maybe as @MBS206 suggested, just swap out those stupid blue relays near the ECU plug.
    • My only regret with the NC MX5 was no space for a spare, even a space saver doesn't fit in I do have a couple of those puncture repair spray cans, but if I get a large puncture, or sidewall damage, I'm screwed until a tilt tray turns up I'm thinking I might get one of those 4WD style of puncture repair kits that have that rope stuff and glue, whilst it will kill any hope of saving a tyre, it might help getting me out from some backwoods road far enough to find a actual tyre shop if the first can of tyre fix doesn't work I'm keen to see how your new toy pans out Uncle Duncan, I'll be moving to the Highlands next year, you'll need to shout out if your heading to Wakefield, whilst I've lost my balls for happy laps, I still love watching those that can
    • Yeah not sure what the warranty was, but it will be years outside it.  I've shot Link a message, will see what happens, I'm told their support is good. It is a plug in, so its a Link board in a factory case, very easy to access both sides of the circuit board by removing the top or bottom cover. To be fair the the Link, although I've checked to the factory connections and wiring specs, as we learned with Neil's car in the early days not all ECUs source power the same way. He'd been running a factory ECU with no trouble for years, but when we plugged a PowerFC in it wouldn't start up, just kept cycling power on and off. We worked out that the car was missing one of the 10a fuses "Electronic Parts", and to Neil's knowledge it had never been there. Turns out the ECU pulled its main power from that source not the same place the factory ECU did.  Point being....there are multiple battery and ECCS power sources in the factory ECU, and multiple grounds as well....not telling from the outside exactly what the Link uses (and doesn't use)
    • Now, thanks to sonicii, onto the uneven floor from a tyre sticking 100mm into the boot space. I looked into options to raise the floor to the level of the tyre, and ended up going Extruded Polystyrene (XPS). EPS is what I normally think of as polystyrene, the annoying tiny balls that get glued into a flat sheet but XPS is quite different, much firmer and doesn't crumble if you touch it with anything. I also looked at things like heavy duty seating foam but XPS seemed like the right way. I picked up 3x 1200x600x50 sheets for $40ea. Initially I was looking for 100mm sheets because I needed to make up a 100mm gap, but as it turned out 50mm was available, much easier to work with and made it simple to store the tools I used a simple 15cm foam cutter to make the shapes. With some practice I was able to make reasonably clean cuts but I don't think Clark Rubber are going to be calling me to offer a job. https://www.ebay.com.au/itm/405092315205?var=675175481574 First layer in place, 3 dimensions are tricky! Second layer in place, bringing it to level with the top of the spare Cutouts in the top layer for the tools With floor back in place, nice and flat with 100mm stolen but no real impact on usability
    • Sounds like a good idea to me moh
