Hi,
In the next week or so i'm looking to buy a 32 gtr.
I know they're an awesome car and i also know they are aging but i haven't heard much about problems apart from the oil pump drive breaking. I'd be interested to hear any info from owners out there who have had any troubles.
Thanks in advance,
Stuart.
https://www.sau.com.au/forums/topic/116650-buying-a-32-gtr/
Ive had my 32 GTR for a few months and have replaced the ECU in it. Not too sure if thats a common problem with the 32's, but i know the Air Flow Meters are a fairly common problem. Engines are also getting old, and would probably be looking at a rebuild, especially if theyve been thrashed or driven uber hard in their liftime. Hopefully you find a car that the previous owner has already taken care of most of the problems the car may have had. This way you dont have to deal with many of them down the track. My knowledge with this vehicle is still very low sorry. Hope it helps though.
https://www.sau.com.au/forums/topic/116650-buying-a-32-gtr/#findComment-2145624
A dog is a dog, just cause its got a GTR badge on it dont think it cant be a lemon.
Engine/Turbo all you can do is check for excesive smoke from exhaust, check to see if timeing belt has been done, and if so the water/oil pump.
Driveline/Clutch check to see if clutch is holding up or slipping, change gears quite quick under load to see if syncros are ok.
Check brake disks for cracks.
One of my AFM's went in the first week.
Try and avoid 1989 GTR's if you can, most of the good ones are long gone.
A modified R32 costs about the same as a clean stock R33 , decide wehter you want the newer cleaner GTR or the modified faster one.
You can often get a FEEL for a cars state of health and condition by driveing it and giving it the once over, other than buying it from a dealer, thats about as good as it gets. GTR's with full service histories are rarer than a Honda Civic without a Mugen Power sticker... :D
Edited by mazgtr
https://www.sau.com.au/forums/topic/116650-buying-a-32-gtr/#findComment-2148219
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
