As in title..
Im chasing either 1 wheel, or perhaps a pair, of Volk Challenge F-Zero 18x9" rims
+36 to +40 offset acceptable
as in pic:
http://forums.toymods.org.au/index.php?t=getfile&id=16766
have cash, will travel :P
[email protected]
[email protected]
0409603238
cheers
ed
Edited by ed_ma61
I have a pair that are rough on the outside.
doesnt concern me at all :P
where abouts in melb are you located? i could either arrange a mate to pick them up, or I'll arrange a courier.
can you send me some pics demonstrating overall condition? More than happy to make a resonable ofer following pics...
[email protected]
cheers
ed
Edited by ed_ma61
Unfortunately these wheels werent 18x9" (thanks anyway ahmed)
so... still on the hunt for a pair (or even a single rim)
please drop me a line if you know of any available...
[email protected]
0409603238
Cheers
Ed
    • That'd be right ~ the early RE5R01A is pretty much the same as the RE4R01A in many ways ; problem is they made lots more 4-speeds than 5-speeds.... I'm in AU, so you'll need apply the US supply scene... https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/Mazda/RE5R01A/#scroll-electrical_components This'll give you the aftermarket parts listings -- you're looking for #56712 & #56713
    • Haven't received that part yet, but seeing as you mentioned it I do have some aluminium foil somewhere.... it'll be good for a laugh
    • At a guess being carb all the dash loom will be different & will probably need more work there or replaced.
    • yes easily doable was very common conversion around 15+ years ago Require: Sr20 cross member and engine mounts sr20 gearbox or bell housing if manual CA already sr20 loom and ecu sr20 radiator (or make a cross over pipe to us CA style radiator) sr20 engine All parts can be sourced from an s13 Will require some mods to engine loom to body loom plugs but plenty of info out there on that.
    • Also check the factory 2 wire coolant sensor is functioning properly and plugged in. Ignore the dash, the dash uses a different temp sensor.
