  • Replies 92
Just checked the tracking details and it looks like most of you should receive your power fc's by tuesday or wednesday.
The remaining ones should be sent shortly, I will let you know asap.
:wave:
Seeing as though the group buy is over, gR33ddy. You said in an earlier thread that your stock kw with a few mods and the stock ecu was about 150rwkw then jumped to 183 with the power FC yeah?
Any drop in fuel econemy with this? Would be very interested in one of these next group buy (if u have one that is)
Excellent! Its good to see that they are rolling in.
Feel free to give me some feedback if you are happy with your item and the transaction (click here for my trader ratings) :P
sorry about this silly question,
whats the differences between power fc and safc2?
Alot of difference. SAFC only does air fuel adjustment. You need
to also control timing. I had an SAFC for a while and just recently
changed to a power fc. I will say *DO NOT WASTE YOUR TIME* with
an SAFC. Yes cheaper but no where near as good. Also these prices
that gR33DDY is doing them for are unbeatable. Keep up the good
work. :unsure:
any of you uys know if a 34gtr commander will fit on a 34 gtt & work properly?
please help?
cheers
steve
The R34 GTR commander wont work on your GTT.
The R32 GTST commander will though.
Let me know if you want one as I can supply :P
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their reliability is proven, performance can be predictable, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
