hey just wondering if anyone on here has experience spraying clearcoat acrylic laquer?
i've got rear lights sprayed in metallic grey and sideskirts/front bumper in normal grey (both acrylic) and have sprayed about three coats of clear over the top
problem is that it a bit orange peel like and need to get that 'mirror finish' and have tried 1200 grit wet/dry which made it look speckled and cutting compound didn't work either ;)
any advice what i should be doing?
thanks
matt
https://www.sau.com.au/forums/topic/11670-spraypainting-clearcoat/
the bodykit parts were fibreglass and primed
.... and spraying clear over the top of previous coats which were smooth (wet/dry 1200 grit before applying clearcoat - except for the metallic because this will ruin the flakes).
i have tried to put it on fairly thick so i dont get overspray but still a bit orange peel and i dont know how to get it mirror finish looking if it is flat
are you applying it right?
see the attached pic
point the gun / can slightly (about 30 degrees) into the direction you are spraying, and move across at a pace where you are applying just enough paint before it begins to run. This will ensure you dont get any overspray....
also make sure the area you are spraying in is well ventilated, so that any overspray floating around doesn't float onto the surface.
also other things to consider, is the surface clean of dirt, grease(most important), and dust?
if using a can make sure you shake VERY well, and the nozzle is clean.
if using a gun, make sure it is also clean, and that you have adjust paint / air mixtures well, and that the stream is not comming out too strong....
there are many factors invloved in spray painting....... cant realy diagnose the situation with seeing all equipment, etc...
Hope this helps
Zahos
zahos - thanks for the info. i'll try and get the spraying right - im using a gun and getting the right pressure (30 psi) and mixtures is difficult
im using wax & grease remover and making sure the surface is flat (1200 grit)
main thing is also what to do once the clear coat is applied (polishing etc)
matt
Since it is not going to be sprayed in an oven, make sure you apply about 4 coats of clear (maybe 5). Once done, you will still have a little bit of orange peel effect.
Before polishing, get some cutting compound (this is a little rough, and may have some chunky bits inside). Dilute a small amount of this into water (mix well), then apply onto the sprayed area (not on the same day you spray as it will still be too soft). Once it has dried to a haze, buff it back. (It would be much better if you didn't do this by hand). Once you have buffed it back, it will look really dull, but dont worry, it's supossed to.
Next use a polish (not cut and polish, just polish). Repeat the same (maybe twice if needed), then wax it too. I know it sounds like a lot of work, but it is b/c you are not painting in an oven, where the temp is just right, and there are fans to suck all the overspray...
George
alright - i'll try about 4/5 coats of clear then and then cutting compound.
i've tried cutting polish before and it gets in the orange peel of the paint. thats when i eventually resort to wet 1200 grit to get it smooth, but that makes things worse
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
