MrStabby Posted May 7, 2006 Share Posted May 7, 2006 I have the gearbox shaft inside the pressure plate "fingers", but it needs to be about 10-15 mm higher to get into the clutch plate splines - problem is that the box is already hard up against the firewall. I've tried jacking the front of the motor, but this doesnt seem to prompt the rear of the motor to drop. Any tips for getting the box in? Tnx, Kot Link to comment https://www.sau.com.au/forums/topic/116736-r32-gtr-gearbox-install/ Share on other sites More sharing options...
wrxhoon Posted May 7, 2006 Share Posted May 7, 2006 I have the gearbox shaft inside the pressure plate "fingers", but it needs to be about 10-15 mm higher to get into the clutch plate splines - problem is that the box is already hard up against the firewall. I've tried jacking the front of the motor, but this doesnt seem to prompt the rear of the motor to drop.Any tips for getting the box in? Tnx, Kot You will have to twist the box so you can clear the tunnel then twist it back to normal. I hope you are doing it on a hoist, its a bastard of a job on the floor.. Link to comment https://www.sau.com.au/forums/topic/116736-r32-gtr-gearbox-install/#findComment-2146849 Share on other sites More sharing options...
MrStabby Posted May 13, 2006 Author Share Posted May 13, 2006 Thanks for that - the gearbox is back in, and i'm enjoying the new single plate! (anyone want to buy a dual plate OS Giken in good condition?) Yes i was doing it on the floor - son of a biatch! Rgs, Kot Link to comment https://www.sau.com.au/forums/topic/116736-r32-gtr-gearbox-install/#findComment-2164023 Share on other sites More sharing options...
wrxhoon Posted May 13, 2006 Share Posted May 13, 2006 Yes i was doing it on the floor - son of a biatch!Rgs, Kot Say that again. Link to comment https://www.sau.com.au/forums/topic/116736-r32-gtr-gearbox-install/#findComment-2164349 Share on other sites More sharing options...
