hey guys looking for a trust front bar for my r33. Wondering if you know of any good/reasonably priced shops. Cheers
been a bit of talk about www.psiparts.com.au , i emailed them about the same front bar [email protected] and they are stocking them soon, i bought a few things reasonably priced so hopefully the front bar is pretty cheap too!!!
https://www.sau.com.au/forums/topic/116771-trust-front-bar/#findComment-2180341
where are you located and for what model R33 is it for?
reason asking is because I have a friend that got a good deal recently for a trust front bar for a series 1 gtst r33. might be able to hook up another for you.
thanks
https://www.sau.com.au/forums/topic/116771-trust-front-bar/#findComment-2188396
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
