hi there,
i have a slight problem with my RB25... when i start the car and drive for a bit, reving it and everything else is just fine...
but i recently experienced this weird idleing issue... when the engine heats up (water temp >~80 degrees) the engine idleing revs begin to jump up down between 550-1100 rpm... ??? ... once when i was reversing into my garage it even stalled... it really sux having to keep the revs with the gas pedal in the >1000rpm area when standing at a traffic light :O ...
i tried changing the engine idle revs in the PFC to 850, but it still did it... should i maybe change the engine correction factor? or what other gimmic does the PFC pro offer that could influence that (dont have datalogit)?
or could it possibly be:
Faulty coils - not really since the engine revs good?
Faulty injectors - same as above
Stock BOV is replaced with a proper one
all hoses and other air hoses arent losing air
plugs are brand new
another maybe important thing to notice here, is that i noticed today in the dark garage, that when the engine does this 500-1000 rpm up and down, i saw that the lights from the tacho and headlights were also dimming as the revs changed??
:D
any clue?
nico
I've had this problem. copy the tune data, ETC, DATA INIT, YES, poweroff.
Perform self idle adjust and all will be well. Make sure u do it with warm engine, ie water temp at 80deg. As a last resort check airflow plug and wires and also look at SENSOR SW / CHECK when it idle hunts, see if anything is obviously out of whack or bouncing a lot
@R33Deviat: i was also thinking on the grounding issue... could well be the case... have to check on that...
@Mashrock: i just checked on that feature, and looking at pauls PFC FAQ, my boost thingy is off... also the 02 correction thingy is also off...
@paul: i was also thinking about that, but the prob with that is that i received a good map from a tuner, and inputed all 800 values for IGN & INJ with the hand-controller :( ... i just u know how much work that was... will try all other things, before doing this again :)
thanks everybody!
nico
thats the problem :) ... there were no skylines imported into my county (Austria / Europe) and i am the only one who has an RB25DET in whole of western europe (except england and maybe a few crazy finnish people) ...
both are around 5.000+ kilometers away... have to do everything myself :( ... but the sound of the RB makes it all up :(
but thx for the offer :(
nico
i am using an apexi bov...
but could u explain how this can influence the idle only once the engine is hot and not the whole time?
is there a setting in the PFC pro that i can tell the engine to keep the same revs/parameters/corrections that are set when water temp is ~70 degrees , once i have gone up to ~85 degrees? this cannot be achieved by the REV/IDLE settings... tried raising to 890rpm, but engine runs at ~650rpm :P
thx,
Nico
Edited by T-u-R-b-O
@rob82: i have a good BOV installed and factory one is removed... i unfortunately don't have a catch tank and one of the pipes sitting on the camshaft cover (the one that "should" go into the air intake pipe, is open) ...
how can i check my base timing?
@bass junky: was also thinking bout this option, but wouldnt this then also effect the engine when it's cold...
just came back from a drive... car runs ok, revs ok, and idle is good as long as engine isnt hot... the moment i come of the highway and stand at a traffic light, the story with the revs between 500-1100 up & down begins again... even my tacho light was dimming again at low revs... also when i used other electrical components like the electric windows, the revs fell very low to ~300 and then up again... :P
appriciate your help...
Nico
You have an air leak through you pcv system. Plug up the rocker cover vent or replumb it into the intake pipe.
actualy to me it sounds like a farked water temp sensor, when they go bad they cause erratic idling and poor performance.
the bad thing about them going south is that they do it slowly and intermitently, so while it might not happen when the car is 'cool' (still at operating temp but hasnt been driven) it will happen after a few spirited runs.
its worth a go and the sensor is cheap as (14$usd here) and it really does sound like that is the problem.
hope that helps...
    • @Dose Pipe Sutututu I would argue that >300rwkW inevitably comes only with a raised boost threshold that makes it more likely to get beaten by the family SUV with a 95 speed auto transmission and TD torque. Ditto the traction problems when it finally does come on boost. I used to love my stock turbo. A little flex of the ankle and it made a sweet little whistle and you had torque immediately. It wasn't fast fast, but it was more likely to win the "squirt to make the gap" type races that actually matter for a street car. I think >300 rwkW requires more capacity than an RB25 can offer (again, for street driving). I have enough experience with driving 2JZs in that space to know that they are much easier to pedal around in than a 25. I keep thinking Greg did the right thing putting a V8 is his car. I can't see myself not having a turbo - but I'd really like a big engine torque curve.
    • This is kinda how I see it also. Could drill down then into sub tags.
    • Let's be honest here @GTSBoy 250kW in a GTS-t would easily get walked by my a family SUV these days. 300kW is the sweet spot, fast enough to keep up with the modern German cars (not from a stand still), fun enough and the motor still can be stock/unopened. Realistically, 400kW is a good number. It's enough to give you cold sweats, still be very street able in terms of the power band (provided you're not an idiot and go single scroll and delete VCT) and only needs a very basic rebuild (or stock if you have a NEO motor). Anything more, it starts to be stupid.
    • Deals off now apparently https://www.abc.net.au/news/2025-02-13/honda-and-nissan-say-merger-talks-called-off/104934438 Hopefully Nissan closes up soon and the family X-Trail becomes a classic too!
    • The west where I live is swarming with birds, not wrong they are bloody loud. In the meantime, do a DIY killswitch - $5 worth of things from jaycar, easy as too. The west is copping it with car theft lately, especially the big shopping centres.
