Hi, I'm having problems with my fuel gauge on my manual 1996 Skyline (Series 2), lightly modified. It started happening last weekend, the fuel gauge or the needle shows that I have no petrol, but I filled the car last week. When the car is stationary the needle starts to climb up and when I start moving it goes down? There were no other warning signs that was flashing on my instrutment and the car is running fine. I checked the underneath the car for any leaks and check the fluids on the car, all seems to be OK. Could it be my fuel filter or fuel pump to be faulty?
Also a lot people are hearing humming or whinning sounds from their differential, my car seems to have these symptoms. Can anyone recommend a differential specialists?
Thanks.
https://www.sau.com.au/forums/topic/116817-fuel-gauge-problem/
with the fuel gauge, I would say its the fuel pump and rod laying around in your tank. It would ahve come off the hook that it sits on. if this is the case, put it back on the hook. But if you are going to check it, and you do have future plans to upgrade your car, I would suggest replacing the fuel pump when checking this. its a c*** to open.
i also have that noise, it sounds like the tailshaft is loose or something mechanical at the rear of the car. mine does it when I'm in 3rd gear and doing about 40km and i left the foot off the accelerate petal and no braking. I would like to know what it is, or how too fix it.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
