Ive been asked a few times now about how hard it is to drop the subfram on skylines in order to install these Noltec subframe mounts.
Id like people here to add anything that may help others if they attempt to do this themselves (with help from mates etc...)
Firstly u need a pit or the car up on stands (the rear has to be jacked up on the chassis, not part of the subframe as you are removing it)
Then u need to disconnect the tailshaft. Undo the rear strut tops from the body. (On a GTR the lowers are a U bolt - so they would drop out when the subframe is lowered??) Then clamp the brake line, and hicas line and disconnect them. Now check out your cat back exhaust. If yous is a bolt on sytem, unbolt the rear muffler and your away. If yours is a welded system, just remove from the cat to the rear.
The rear should now be free from the driveline. The only thing left is the 4 bolts going through the actual subframe bushes holding the subframe to the car. Place a jack under either side of the subframe and remove the 4 bolts. I suggest u get hold of an air compressor, as these may be stiff bolts, or may require soaking in Rost off (a silicone creeping spray that works its way into the thread to loosen the bolts)
Once the bolts are out, then have someone on the other jack and together lower the subframe down. If you havent removed the wheels, just roll the whole frame back and away from the car :( Its out now have a break...
Now u need to get the bushes out using either of the 2 methods. First is to use an oxy torch to blow/burn out the bushes. This is extremely smelly, as u will have clouds of black smoke pouring out, so not recommended. Second method is to go down the hardware store and buy a hole saw slightly smaller than the bush. Use it to cut down the hole the bush is in and it should remove most of the bush. There is then a collar that is normally on the outer of the bush (i havent seen the std bushes, so this may or may not be in the subframe, have a look before u install the new ones) See 1st diagram for pics of replacement bush with collar.
If there is the collar in the frame, u need a hacksaw to remove it. Undo 1 end of the blade, push it through the hole, and redo the hacksaw up. Now cut the outer collar out, taking care not to cut the subframe going too far.
Now grease the bush a little, and sit them in where they go (the right way up too) Then using a mallet bang them in.
At this point you can install urethane pinapples to tune (angle) the subframe for traction as well. (see diagram)
All that is left now is to re-install the subframe the way you took it out. Once it has been installed, you may need to bleed the brakes, and the powersteering (hicas).
Please allow a weekend to do this, and have a mate on hand, and a ride organized to go to the hardware store (holesaw). Maybe to repco for brake/ps fluid also.
I find a BBQ and alcohol will have many hands on deck if needed.
Anyone that has done this, or can offer advice please do. Im sure it is the same for GTR and GTST (apart from lower shock mounts, and Attessa - someone help on this?)
later i'll add pics, and get this moved to the tutorial section as well.
Please add any comments or suggestions to help.
Edited by Bl4cK32
https://www.sau.com.au/forums/topic/116840-removing-subframe/
A couple of minor things -
The brake lines dont need to be taken off. Unbolt them from the hub and leave them wired up to something, one of the little holes in the body work (there are a few under there)
Remove the struts comlpletely as it will just get in the way when you drop the subframe.
As for installing the new bushes with a hammer, i think you will have a few problems. I have recently installed new lower control arm bushes which also have an outer sleeve similar to the ones shown. (though half the size obviously). They are a very very tight fit. I am very doubtful you could get the bushes in without a BIG press and the right dies without damaging them. The lower control arm bushes took 2 guys, a big bench vice and a metre of pipe on the handle to get in. The subframe bushes have over double the surface area of the ones I installed.
Other than that, i think it will be a very worthwhile upgrade once complete.
these will almost certainly require an industrial press to be installed into the subframe. the tricky bit will be getting the subframe onto the press or vice versa. make no mistake it will be a bastard of a job, but by all acounts it will be worthwhile.
http://forums.nicoclub.com/zerothread/97924
Guys heres a s13 subframe with pics on how to do the installation
Would anyone know if the freezer trick would work with the noltec ones? :laugh:
I think the bolt with 2 washers and pressing it in as you do the nuts up would work at least?
Edited by Bl4cK32
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
