everyone on THIS forum should know that aye ?
his comparing something new with his own ride?
if you get in someone elses ride, go for a blat, its kinda natural you flick up your own stick and take measure eh ?
we have an sti lib in our house, its mums, great car, but its boaring as bat shit to drive, absolutly no driver involvement, and you have to fang the ass out of it just to have fun, has lots of grip and is very consistant, but much prefer driving my r32 it feels alive, stis get the mcintosh soundsystem, quite nice!
Edited by Jolinator
hmmm the 06 is one ugly mofo, wonder if the 06 still has a piss weak gb,
the 2.5L would be helpful for hte daily, mod the thing a little and replace the nose with a bit of kit an get a park bench rally wing, fun.
anyone know if the 06 sti has forged internals or if it went the way of the yank 2.5 and is cast.
aparently the 02-05 sti's were all forged internals so a exhuast mod and a cooler and your pumping max octance boost..... food for thought
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
