Hey All,
I am tossing up between 2 dump pipes..
1) BOS IMPORTING
2) CES RACING
Who here has either of these and what was the power increase after install?
BOS IMPORTING one seems better value for money, but the CES one claims very good gains..
Opinions?
Cheers :laugh:
-JD
PS: talking 33 gtst's
Edited by JD-33
https://www.sau.com.au/forums/topic/116863-dump-pipes/
I am looking at getting one myself...
This is what I have at the moment, I am guessing it is stock?
yeah pretty much stock looking. mine is like that too..
Ive decided that im gonna go for the BOS IMPORTING one (only because of all the replies to it in this thread :P ) ... haha
-JD
Will let you know how it goes
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2152163
the one my mate has is just the split dump pipe and its split for about 10-15cm. i'm just going dump only as the car came with a 3" front pipe and i can't see the point in spending $400 when i can get away with $150. if i didn't have a 3" front pipe i'd get one of the BOS ones.
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2155079
screamers are illegal and can be bloody loud.
people dont seem to worry about screamer pipes as much as say no cat .. but the penalties are the same.
you shouldn't see any difference in spool times as this split system only really come into effect once the wastegate opens, therefore it is already at full boost.
noticed on my old setup that it would rev out much cleaner after the 5-5.5K rpm range ..
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2155604
hey guys just wondering i just bought one of these split dump pipes but now i have gone for a high flowed turbo and has much more room behind the turbo in between the wastgate and the exaust . would it make a big difference if i dont have the little metal bit in between to seperate these two?
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2156129
yes the little bit, or divider is half the point of a split dump. without the metal divider between the two they are still likely to cause excess backpressure.
imho a split dump without the divider is kinda pointless
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2156226
i ought the split dump pipe from just jap and was told that it was for the hks turbo so i took it off and it is lost but looking at the gap on the high flowed turbo, it has plenty of room for the metal to split the pipes does anyone know when i can get just the spliter part from?
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2156383
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
