Hi i am still stripping this R34gtt if anone wants anything it will be sent next week i am located in newcastle
Front seats $500
Brakes everything you could ever need $800
Bonnet $400
airbags make me an offer.
Manual dash cluster.Make me an offer.
Standard struts $400
All 4 doors will separate make me an offer
R34 diff $300
Call me if you want any small stuff
thanks..
0412426573
https://www.sau.com.au/forums/topic/116880-r34gtt-parts/
offer $100 for the dash cluster
i onlyhave the passenger side guard it is in excellent condition and it is silver...
I also do have the dsh cluster it has 50k on it i think i will put it in mine and check...
i will be wanting more than $100 for it heaps have people asked me about this before i started stripping the car...i would like to sell the manauk steering wheel with it but i can separate..
https://www.sau.com.au/forums/topic/116880-r34gtt-parts/#findComment-2156774
Do you have a pic of the L/H front guard?
How much do you want for it?
Thanks.
Here is a pic of the guard i just took in the dark i can assure you it is straight though...
As for the speaker covers i will have a look give me a call on 0412426573
https://www.sau.com.au/forums/topic/116880-r34gtt-parts/#findComment-2159596
It is a 4 door right? If so, would u have the passenger side tail light and the plastic cover for it. and how much. cheers.
Yeah i have it but i am not sure if it is in perfect condition i will have a look.....
pm me or give me a cll 0412426573
https://www.sau.com.au/forums/topic/116880-r34gtt-parts/#findComment-2162493
