Fs - Kyb Suspension And Air Conditioner Vent
By DraftySquash · Posted
Yup @joshuaho96 those are the same part numbers I got as well but this kit from Kudos comes up when I’m searching. I’ve emailed them asking if the pic is accurate and hopefully they say it’s for reference only. worst case, I’ll get it off Amayama. But I’d prefer Kudos so it doesn’t take almost a month to come 😂 -
By hardsteppa · Posted
I think there's "some" things you need the data cable to access but - if it's locked and only basic tuned, maybe, take photos of ALL the screens, then hit reset on the hand controller, then enter the same values back in? Giving you the same tune but unlocked. -
If there's no rubber gasket you need a new cap. There should be a rubber gasket, depending on the car. If you are driving the car hard and the power steering is getting hot it will spit out of the reservoir. I have seen people tap the cap for a hose + overflow catch bottle placed somewhere that it will fit. -
Oil pan gasket is 31397-41X04. Strainer assembly is 31728-4AX00. You can look at this yourself: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/er34/3945-rb25det/trans/317 and https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/er34/3945-rb25det/trans/311 Checking online the actual picture of the OEM filter looks like this: -
Hi everyone, I want to start organise buying the parts to do a transmission fluid, gasket and filter*(strainer) change on my R34 GTT Series 2. I've got the part numbers from a tutorial on YouTube (shoutout to The Build Room) and I've found a Filter Kit on Kudos Motorsport - https://www.kudosmotorsports.com/catalog/automatic-transmission-filter-4spd-suit-nissan-skyline-250gt-stagea-wc34-series-p-1609.html I'm not sure if their image is for reference only, but the filter on that image only has 4 bolts whereas the actual one off the video has about 12. So I want to make sure I don't buy some wrong part 🙈 Has anyone here bought the filter kit off Kudos for their R34? Thanks in advance
