As some of you are aware im selling copies of the Banana bar but i have run into a slight problem... I have No idea what indicators are being used in the bar and obviously makes it hard to sell the bar and have no idea what indicators it comes with...
If anyone can shed some light as to what indicators they are it would be very much appreciated.. I have spoken to Nissan and a few other places and no-one can tell me what they are…
Back dimensions are around 90x40mm at the base and span out to a 125x40mm at the front..
Attached is a shot of the indicator…
Thanx again in advance to anyone that can tell me what they are off cheers…
Matt
Also if your interested in the bar Link is below in the Sig....
https://www.sau.com.au/forums/topic/116924-i-need-some-help/
Dark cheers mate but there is nothing... All the indicators has is a Manufactures Number and Both Nissan and a second hand joint have both told me that the numbers mean Jack and im unable to order parts from the given markings..
Hence this being such a hard task
have u tried running the numbers through mitsibushi or toyota, cuz by the looks of those n the dimensions, it looks as its off a pre 98 Mitsibushi Canter (its a 1 ton truck, sorta).....i may be wrong but run the part number through mitsubishi.....wudn hurt.....
ok they are not 180sx ones are they??
Right Hand: B6170-60F00
Left Hand: B6175-60F00
I have been looking at some 180sx kits and the hole looks very very similar in the sqaure shape...but i have no dimentions...
Edited by khunjeng
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
