R32 Bride Seat Rails For Driver Side, Air Vent, Nardi, Safc
Looking for R32 Bride Seat rails for Driver side used or new, Nardi Steering wheel, air vent, safc1 or 2 in Melbourne...will buy from interstate if needed.
Please PM me....
I've brought some stuff from this guy and he's been quite good... I'm sure he'll look after you ! :P
http://www.nissansilvia.com/forums/index.p...howtopic=144086
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
