Howdy...
Do you guys get a banging or a squeaky noise from your parcel shelves when you run some bass through your speakers or crank your sub(s)?
I used to only get it when i was pounding out some low bass and when I was back at the audio store last weekend, I showed one of the guys who started mucking around with the tray from inside the cabin and from the boot. Now i'm starting to notice it just driving along the motorways etc.
I think i've isolated the places where its coming from and now need to try and fix it. i think its the cover from the rear wiper banging up against the back window and also just one side of the shelf where the vents are...
Has anyone else had this problem? I presume its common...
How did you get around it? thick tape, foam, some sort of divider?
If so, where did you get it from and how much was it?
This noise is driving me nuts!!! :crazy:
ahhh thanks Humbla. I have noticed that the shelf is sitting up. Maybe it is something to do with the clips. Have to try and figure out how to clip them down. As i said before, its only one side that makes the noise... perhaps one clip is right..
i noticed my left side (looking from the rear of the car) is loose aswell
i tried getting it back on with the slip but it doesnt seem to wanna sit there either..... i think its weldin time :P
Fixed!
Well... It appears to be for now...
You were right Humbla, the clip was facing the wrong way and just hanging out. Fixed that, then proceeded to put some foam tape stuff in some of the gaps as a buffer between the wiper cover and the back window and between the parcel shelf and metal.
All good! Thanks! :D
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
