the problem is when i drive for a bit there is a bit of hot air like coming from where my legs are located....i have all the heater and stuff off and there is hot air?....is that normal is or something like busted up?
Cheers
Chi
this may be the cause....
before you turn off the heater do you put the temperature down??
even if the heater is off, you will still feel some hot air come through when you leave the temp up.
if this is the case, then its normal.
https://www.sau.com.au/forums/topic/116969-wierd-problem/#findComment-2150484
oh true haha my bad i leave my heater on 32 degrees....and like i get these hot air and im like OMFG wtf hahahah my mates are like MAN UR SKYLINES OVERHEATING....scared me to the shite hahah but yea cheers guys ill put the heater temp to the lowest hahahah....btw is there a point to buy a safc 2 ? would i save a bit on petrol or ?
https://www.sau.com.au/forums/topic/116969-wierd-problem/#findComment-2151815
