Hi All,
This kit is to suit the RB26 Head, so for any of you who have an RB26 or RB26/30 on their cars and you want either big HP or quick ET's or maybe even both then this is for you NOT DREAMERS. The kit includes
HKS T51R SPL Ball Bearing Turbo (traveled 500kms)
HKS T51R BB SPL - 1000 PS Output
COMPRESSOR:
• Wheel- 56 Trim - 76.5 Inducer/ 102.2 Major
• Housing- 100 Inlet / 80 Outlet
TURBINE:
• Wheel- 76 Trim - 82.0 Major / 71.4 Exducer
• Housing- V-Band inlet / V-Band 115.5 mm outlet - 1.00 A/R
HKS T51 Stainless Manifold (new)
HKS GTII 60mm Wastegate (new)
Inlet Trumpet (new)
Speedflow Water Fittings (new)
Speedflow Oil Fittings (new)
As you can see the turbo is the only used part of the kit and was recently checked out by GCG Turbos and said to be "A1 Condition". This turbo has been seen to make 1200HP+.
I have everything in my possession ready to go waiting to make some serious power! If you are genuinely interested either leave a message here or e-mail/ PM me and we can talk further….
To give you an idea this complete set up owes me over $12,000.00 and it is unfortunate that due to some personal financial issues I am going to have to let this go but these things happen.
Looking for $7,500.00 o.n.o NEEDING A QUICK SALE! :)
Regards,
Jimmy.
EDIT:
E-mail [email protected]
Ph Number: PM or E-mail & I will provide my number.
https://www.sau.com.au/forums/topic/116978-hks-t51r-bb-spl-turbo-kit-rb26-head/
HOW MUCH JUST FOR TURBO??????
Turbo $3,000.00 o.n.o
Complete kit reduced to $6,500.00 o.n.o - need the money for other things on the go atm...
This has got to be moved so make an offer to me via PM or e-mail.....
Hi
are you the same guy try to sell the turbo kit on performanceforums?
if yes.it sounds very dodge!!
have look here:
http://www.performanceforums.com/forums/sh....php?t=67203377
Hi Everyone,
I have a complete genuine HKS T51r BB SPL turbo kit to suit a FD RX7 for sale. This kit isn’t for the faint hearted and will produce massive top end/ power! Designed for those who are looking for the big HP and or quick ET’s.
The Kit Includes:
COMPRESSOR:
TURBINE:
HKS GT 60mm Wastegate
Down pipe
Suction pipe
Intercooler pipe
All the necessary fittings and lines for a complete installation
This is all brand new and was going to go onto a Series 7 which I had purchased but due to personal financial issues I had to let go. I would love to hang onto this awesome bit of kit but I am un-sure as to how long it will be before I will get a chance to purchase another RX-7.
If you are genuinely interested leave a message here or PM me and we can talk further….
This owes me nearly $8,000.00 and because I just need to get rid of it and looking for a quick non complicated sale it is on offer for $5,250.00 o.n.o
N.B – This is negotiable and I am looking to sell.
If you have any further questions please don not hesitate to ask.
Cheers!
correct me if i am wrong!!
thanks
Hey champ,
Thanks for your concern, but that’s not me! If you have any concerns either PM me or e-mail me easy as that. Otherwise T400 Skyline thanks for bringing this up.
The person on performance forums looks to be by the name of Matt with a totally different e-mail to me also. Similar ad but different person.
It looks like i may have a potential buyer when i touch down back home from business as well so unless his offer is beaten kit could be sold for considerably less so make an offer.
Regards,
James.
Funny that because I rang the number given by SKYPE (James) and when it went to the message bank the guys name was MATT. Somthing dodgy or can someone explain.
Unless someone comes up with a good offer for the complete kit looks like the wastegate maybe sold to ZIL32R and turbo to MR33...
Current offer on the kit is $4,000.00 so someone needs to come up with atleast $6k to take it all home.
Hi mate
i am not try to be difficult.
but on performance forums.they dont show seller's email.how can you know the email are different compare with you's?
also same reason to sell the Turbo it(financial issues )
and similar ads at same day 9th May.
can you explain??
i am interest the kit as well,but seems very dodgy for me!!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
