hi boys and girls
i am just wondering what big hp skylines are using when it comes to automatic gearboxes.
i have got to the point where my strengthened toyota box cant handle it any more.
i am being pushed towards an al's race glide C4 or a power glide. i still drive the car on the street a fair bit but not more than 4000k's per year. with the new engine i intend to build it will make approx 900 at the crank so it has to be able to handle that sort of power.
any info would be appreciated.
https://www.sau.com.au/forums/topic/116996-automatic-trans-on-drag-cars/
  1JZ.747 said:
hi boys and girls
KEAS.COM.AU SAY EDDY REFERED U BUSTER AND I BOTH USE 1,JPC BRESIANI,RAJB AND ALOT OF BHP CARS USE KEAS
I received the following email from Keas about a week ago:
Thanks for your enquiry. We will get back to you within 24rs to confirm order or answer your query. service@keas.com.au
Haven't heard anything since and they don't list a phone number on their website. Guess they have far too much work to bother.
Adrian
If you are going to drive on street I wouldnt recomend a 2 speed, especially on a smaller motor with a turbo as there is no torque to get the car to moving when off stall and you will hate that around town trust me.... For that much power a c4 might be okay, keas can build you a killer jatco that will take it, personally th400 are my fav 3 speed, but you will probs have probs adapting the thing and it will cost a bit, just ring keas they will sort you out, alternatively if they are too busy try hugo's in melbourne, can build a tranny that bloke!!!
I didn't like what I heard at Keas so I ended up going to Mike at MV Automatics in Adelaide.
I honestly believe Mike is the most knowledgeable person with regard to Jatco's in Australia and discounting the engineers that designed the things right up there in the world. He gets jobs to do from all over the world (was building one for a Russian customer at the same time he was doing mine).
The only thing is, he's in adelaide.
phil cruickshank built my auto
i think pvl-747 is selling his glide its the same as mine as he isnt finishing his car pm him
hardcore have never worked on my car but they produce some nice cars
Edited by jas/slo32
Fred from Pro Trans in Southerland builds our autos. Built C4 in our Gallant, Builds a mean Powerglide also.
Should give him a bell, excellent bloke, will advise you on the best way to go.
9587 9594
  1JZ.747 said:
hi boys and girls
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
