Hey
I have one more mate who wants to enter... he doesn't drive a Skyline though, can he enter through RENEW? He owns a 13B RX3
Also, do we provide our own numbers on the day or is this catered for by SAU? :nyaanyaa: *Adam*
  • Replies 513
Posted Images
Neil will probably be there. But, we are encouraging all entrants - from both RENEW, SAU and anywhere else for that matter - to arrange getting their own numbers. Be they a piece of paper in the window, some tape on the side of the car, or the little stickers that a lot of you guys used at Oran Park.
Any numbers that we may be able to provide would be in an emergency backup situation, but we cannot guarantee this.
In the next week or so, Nathan (MrG) will send out an email to those guys who have entered, advising you of the number you have been allocated.
Craig
RENEW Secretary
Do we just randomly pick a number between 00 and infinity?
And stick it on like what Adam did last time? (not Abo Adam, other one)
Hey doodz, if you mean me all i did was print up my number on A4 landscape as big as it would fit on the page, then i got clear contact that was about 20mm bigger allround then the A4 paper and stuck it on my car! So paper is protected just in case it rained. :D
YA :D hehe.. Is the contact ok for the car's paint?
I might do that unless someone can supply stickers with numbers
Isn't Steve N1GTR supposed to be on that list?
Not after Monday mate :D
Sounds like their is plenty of interest in this trackday, pitty higher numbers weren't available (no doubt 5 or so will dropout by lunchtime tho).
No doubt all will be GTR's
YA :worship: hehe.. Is the contact ok for the car's paint?
Just use race tape - Didnt mark Shauns car at all
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
