WOOOHOOOO IM IN!!!!!!!!!!!!!!!!!!!!!!!!!
d00dz --- 1st Time
Primordial --- 1st Time!
nath95
R31deviat --- 1st Time - SLOWer than Liz.
Stolly
D_I_F --- 1st Time
Sh@un ---wasnt timed first time there, did 1.27 at OP GP (he cant get to a computer)
satanic --- 1st Time
yogi000 - been before, but never timed
Oz GTR02V --- 1.12
godzl1975
tuitahi
lingering soul ---- 1st time!!!! YEAH GONNA OWN U ALL!!!
  • Replies 513
Posted Images
d00dz --- 1st Time
nath95
Stolly
D_I_F --- 1st Time
Oz GTR02V --- 1.12
godzl1975 ---1st timer
tuitahi
d00dz --- 1st Time
nath95
Stolly
D_I_F --- 1st Time
Oz GTR02V --- 1.12
tuitahi --- 1st Time (and so are my other two places)
Abo,
Do you think we will be able to take a couple of car loads round for 2-3 laps at the start of the day? Aaron McGill does this with his days and it normally helps the first timers a lot. They get to see what a skyline can do and roughly what gears and pace they can do around the track.
I find it normally slows down the hoons and gives the first timers some confidence to go a little quicker.
Let me know your thoughts.
Looking forward to the head to head battle again!.
Hows your secret mod going?
I am having my cam sprocket's and 100 Ron tune done this weekend, it will be interesting to see what difference this makes in the real world.
  Oz GTR02V said:
Abo,
Shotgun! :D
  RENEW Member said:
Oz GTR02V,
WRT to the first timers, RENEW will be running the day in a similar format to our previous days. ie a first timers familiarisation session at the start of the day.
Craig
Craig, last time we did it one on one and I think there were some people that missed out. With this many first timers it may take some time to get through them all. My suggestion was to have 3 passanges and do a group run as per the Aaron McGill days, I find there is heaps more questions and a better flow of info when you get a couple of people in the car. In addition every one gets a good look at the track, gear selection and line.
Your thoughts?
Your thoughts?
Hey Paul,
If Wakefield Park allow us to do this we will consider it, if not we shall stick to the current schedule.
Cheers
Nathan
Received your forms tuitahi :D
Will keep an eye out for yours lingeringsoul and R31deviat if u can get yours thru as soon as u can :rofl:
  tuitahi said:
Another newbie question...
Do we need a battery location sticker?
It is not a requirement for Wakefield Park, but if you are likely to attend further events that are CAMS sanctioned it will be required so it doesnt hurt to have it.
RE: Semi Slicks
These will give you 3-4 seconds a lap improvement over street tyres at Wakefield park provided everything else is up to scratch including the driver :) Certainly not necessary to cut some decent times and still have a great time :D
  MrGenius said:
Lots of 1st timers, you boys and girls are going to have a ball :D
Waiting on entry forms from the following;
A31deviat
lingeringsoul
Kevin Leung
David Montauti
Um forms??? Huh?? I sent mine! :)
Oh hangon on seacond thought that was Wakefield.... ahahahah :D
Will search for the form and get it done asap
Oh and its A31Deviat... sif drive a R31 Skyrine........... :D
Cefiro baby, don't you forget it :w00t:
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 馃ゴ
