  • Replies 513
Posted Images
Yep, I had a ball... after snapping a wheel stud on my FIRST LAP! :)
After that drama I managed to fit 23 laps into the afternoon and got a best time of 1:15.9!
Big ups for Steve and Adam for organising the day. It was a shame about the hiccups regarding water and power and keys etc, but it was a great weekend all the same! Nice to meet some faces I haven't met before too!
Cheers!
Where your photos at Corrinne?
Lol.. whats email do you want me to send them to.. i have a few movies clips as well.. i will be uploading them later.. and i will post up links
Haha stan i have photos of your lil pet in there :)
Cheers!
you poor thing! But a top effort cutting a 1.15 with very little practice you had on that track! Well done!
Well done to Dave and Ando 1.13 and 1.14 respectively... you legends!!!!
What a fantastic weekend! Well done to Adam and Steve for organising! :)
satanic @ optusnet.com.au - Thanks D_I_F
Also thanks to all the non-competitors for making the effort to come out and cheer the SAU boys and girls on!!! Great to see so many people by the wall each time we flew past!
I had an awesome time too!
Now I need a set of semis and more practice to cut my time down! What sort of time should I look at running on street tyres and stock boost/turbo. I managed a 1:18.2, kinda hoped for better. One of the guys from Renew suggested I should have been trying for a low 16 maybe even 15.
I was on street tyres and stock boost my car is nearly completely stock.. lol.. that was my first track day too..
but i was happy with my time.. hopefully looking to cut it down a few seconds next time :)
Thanks guys and gals for the kind words (and vic of course for the can :))
Also a HUGE thanks to the guys that took me for a few laps - and yes, ill get back out there myself asap :)
Here are some of my pics
Sorry about the quality, norm turned the quality down on my camera on the way down, i didnt realize and therefore the pics arent all the best.....
Also there are a few vids (turn sound RIGHT up :) )
You can really tell when the camera settings were changed
Video's
(will be up shortly, uploading takes a while)
more than a few seconds!!! :) i didn't see you drive, but i'm guessing confidence is the only thing holding you back! just mow those pesky boys down! :)
man I just check the time sheet again.. there are way too many good times to mention!!!!
Adam, Shaun and George.. nice work!
James (lingeringsoul) did a 1.19 .. first time on the track!
and Paul!!! Good times as always and thank you so much or your help!!!! Hopefully next time I'm out there I can knock another second or two off.... was very frustrating sitting on 1.19 and 1.20 for the majority of the day!
Thanks liz! Good to see you are making progress too! :)
Adam had a cracker with 1:13! I was surprised and impressed!
Lol.. for sure.. want to work of my braking skillz abit more.. lol..
I want to be up there with the boys :) i absolutely loved it and i think more girls should get into it :)
For those not 110% sure about the worth of semi slicks, in Shauns car, we were sliding all over the place, how he got that time with those tyres and suspension, i will never know. Paul on the other hand, cracked the 10's, and its clear why - the grip his car has is nothing short of astonishing!
Also the willingness to break their cars MAY have had something to do with it :)
Shaun spent about 2.5 hours replacing a wrecked hose that limited boost to only 7psi (down from 15), and Paul discovered he had broken one of his brake rotors clean in two!
Well done guys - fantastic times, cant wait for the next one!!!
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
