Hey guys here is my issue,
On stone cold start ups only I get smoke out of the exhaust which I'm pretty sure is burning oil. It lasts about 3 minutes then goes away. Car runs fine otherwise. It's not condensation, there is enough smoke to fill the whole garage.
Engine is about 4000k's old.
Didn't get this smoke at run in or in the time after that before now. Basically I put some 10w60 oil in there for about 500km's cos that's all I had handy and that's when it started. I changed back to 10w40 and still the same. I thought maybe I had overfilled it but tried with less at last change and no difference.
My catch can doesn't go back into the intake.
I can't think of anything else atm.
Thanks.
https://www.sau.com.au/forums/topic/117011-smoke-from-new-engine/
if you boost up, does it go away? if so, could be valve guide seals. if it smokes more on boost, could have burnt oil rings..doubt the rings because it goes away...maybe your cooler is catching oil when motors not running, and suckn it in when you first start up. which means, turbo seals... OR etc etc etc..... check the plugs, this a wasy to see if its being burnt IN the engine or not
Edited by danielson
If its blue smoke it doesn't sound good Adam. I dont think the oil has anything to do with it. Are you sure it goes away after warm up ?
Any blue smoke under hard ecceleration? Try going down a log hill in a suitable gear so it maintains speed at high rpm ( above 5000 if possible), whe you get to the bottom of the hill give it full throtle and watch at the rear for blue smoke. Watch your oil consumption closely to see if sge uses more than before .
It definitely goes away and it's like a switch.
It goes:
Start engine, exhaust is normal for about 20-30 seconds then smoke comes out and it smells bad. About 3 minutes later it just stops completely.
I will try what you say Jerry. I'll also check out my intake pipes and cooler if possible.
you mentioned putting 10w 60 in....i've been using 10w 60 since i got my car from japan, (7000kms ago) Castrol R 10W 60 went in at compliance, and again after 5000kms and my car has never blown any smoke...
just mentioning that as i dont see that oil being the cause of your problem :ermm:
By what you say it sounds like you have oil sitting in the pipes and as soon as she burns it, she is fine. Where does the oil come from ? It could very well br the turbo seals leaking ever so little, oil drops in the dump and sits there until you start it up and burn it. The worry here is that its there ( smoke ) for 3 minutes !
I'm sure it wouldn't be stem seals ( not when you have just replaced them ). It shouldnt be the engine either, as its all new and the rings must have bedded in because you didnt have the smoke before. You can easily eliminate the engine by doing a leakdown test, any problems there will show up.
you sure it isnt the turbo? e.g oil leaks slowly from the seals while car is off, when you start the car, its takes 30 secs to start burning the oil, after 3 mins the oil is completly burnt out.
the leak could be so small, it wont cause any smoke while driving. but when you stop it starts collecting up in the exhaust side (or where ever)
steve
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
