hey peoples...
Just wanting ur opinion on selecting a new bov for my car.
Not sure which one i should get...
Has to be able to be plummed back...
Sound good and perform great...
Been this bout the hks ssqv. Can this be plummed back?
wats it sound like?
cheers
Guesty
https://www.sau.com.au/forums/topic/117076-bovs/
  • Replies 50
why keep the stock bov?
im changing just about everything thats bolted onto the engine.
new turbo, apexi power fc, new plenum, manifold, external wastegate, 800cc injectors etc etc
wouldn't i be better off upgrading, i'll probably have the new bov (which ever i get) plumbed back.
thanks for all the help so far...
https://www.sau.com.au/forums/topic/117076-bovs/#findComment-2152698
Best BOV on the market is the GTR BOV's
Stock, factory Nissan GTR BOV's.
You didnt say you were changing a-b-c-d-e-f & g...
So hence everyone said, stock BOV. You gotta tell us your plans, we cant "guess" that your upgrading everything :O
Having now knowing your going a bit more in terms of mods etc etc
I would now say, Stock GTR BOV's
Just because it doesnt have a brand name like "HKS" doesnt mean its not the best item for the job
https://www.sau.com.au/forums/topic/117076-bovs/#findComment-2152848
"why keep the stock bov?"
why not keep the stock bov? :O
im a big fan of if it ain't broke, don't fix it. if the stock unit isn't broken, you don't need to change it. more money you can spend on doing other things anyway.
https://www.sau.com.au/forums/topic/117076-bovs/#findComment-2152853
IF and only IF you choose to buy aftermarket.... I can reccommend Turbosmart as I have one myself and have used them for years and never had a drama with stalling or leaking. I have the VeePort Type II model which can be adjusted so the loud woooshing sound is only heard under full boost. Otherwise, its quiet and all you get is a bit of flutter.
Unfortunately, without any type of management, my car still runs the stock ECR33 ecu which is nice n rich, and the BOV certainly doesnt help, tuning is neccessary.
Edited by _8OO5TED_
https://www.sau.com.au/forums/topic/117076-bovs/#findComment-2153384
my hks bov has never caused me to stall. i put a quiet adaptor fin to shut it up though..
i know most aftermarkets do have stalling issues..
get what ya want man see how ya go..there so cheap..just keep your stocky in case
LOl @ this bein the most talked about topic in forced induction
Edited by thizzle
https://www.sau.com.au/forums/topic/117076-bovs/#findComment-2153726
he has said that he is chainging computer so he isn't going to have the stalling problem. my mate has a hks ssq on his r33 with stock computer and has no problems, and i have the stock and i have the odd stalling prob (changing plugs and taping up coil packs tonight). after being in his car both before and after the aftermarket bov, i can say, from my experience only, that the aftermarket bovs have a slight performance gain as they vent more air. this isn't very noticable on skylines, but on my old 180sx it made a huge difference.
the ssq does make a high pitch squeal that sounds pretty cool, and at light throttle lift off's you get a flutter. if you plumb it back you only get the flutter.
the other alternative is to get an aftermarket plumb back such as the gfb or turbosmart. if you want outright noise the gfb mach 1 (atmo) is probably the loudest i've heard.
https://www.sau.com.au/forums/topic/117076-bovs/#findComment-2153753
I go aftermarket BOV because I just got sick of hearing that noise,
like a loong ssssshhhhhh noise, stock bov makes, even on light pedal. its more embarass if u hit a hump, and it sounds like wsshhhh wwwssshhh, *cover my face*
I will see how it goes,
i heard few pros and cons about HKS,
but yea, 160 delivered.
cant go wrong!
*fingercross*
the ppl on here recommended Stock BOV, i thought they just like the sound.
https://www.sau.com.au/forums/topic/117076-bovs/#findComment-2153827
If you dont like it, put the stock AIRBOX back on there.
People reccomend stock as it stips stalling, overfuelling etc.
Its hardly anything to do with wanky noises
https://www.sau.com.au/forums/topic/117076-bovs/#findComment-2154271
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
