If its a 1993 model I would be betting the old crank design... have seen a early January 1994 model with the small drive and a late January 1994 with the new drive, so im assuming it was somewhere in that period it cut over for all new cars.
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
