hey guys,
i need a little help with a few problems with my r33.
the problems are:
Stalls when i ease off the accelerater.
Idle goes up and down.
A knocking coming from the rear of the engine.
and when i am boosting the whole car feels like its shuttering. ( when i hit 4500rpm)
Could this be the air flow sensor? or maybe some thing else?
i am taking it to a auto electrician tomorrow but just wanted to get the opinion from some of you guys.
thanks heaps :O
https://www.sau.com.au/forums/topic/117111-r33-problems/
Id spend the $130-$150 on a full service and tune if you havent already done so. I found a few little issues like lagging and for air flow solved with a good service and a decent air filter (im using one called "uni filter"), costa about $80, running beautifully now, very smooth.
Hope this is an option for your ride, all the best.
Regards Evan
PS) Please checkout cruise for a cause post in the SA events posting page
Edited by EMZ R33
https://www.sau.com.au/forums/topic/117111-r33-problems/#findComment-2184021
Dude, what fuel are you using? Ive recently started to use a 10% ethanol blend of fuel and have since (second tank full) had stalling issues. Im going to start using Shell or caltex only high octane fuel. I still had about 3/4 of a tank of 10% ethanol fuel in the tank and i filled up with 98 octane and it looks, so far, to have fixed the prob.
Kind reagrds Evan
https://www.sau.com.au/forums/topic/117111-r33-problems/#findComment-2198688
EMZ R33 .... it is my (and many other forum members) opinion that both Shell and Caltex so-called Premium fuels are shite, and neither guarantee a 98 ron rating necessary for our engines to survive a decent lifespan.
I ONLY use Mobil 8000, or BP Ultimate .... other fuels that you have mentioned have given me detonation and other problems.
Also, as far as I know the 10% ethanol fuels are not suitable for RB25 unless they are specifically tuned for it (hence why you have had problems).
https://www.sau.com.au/forums/topic/117111-r33-problems/#findComment-2199161
Check that you don't have any air leaks too make, if your engine is sucking in air that isn't going through the afm it'll be running lean as hell & will cause your hunting with the revs too.
I've got a problem with mine leaking on the vacuum line to the boost gauge sensor. I fixed it once but the hose I got wasn't good enough. Need to get some fibre reinforced hose the right size. Bloody hard to find.
I May need to try Nissan themselves, I know local delivered 200SX's use the right stuff.
https://www.sau.com.au/forums/topic/117111-r33-problems/#findComment-2206966
hey man, id check your vacuum lines from your turbo. i also had this problem. There is a hose at the front of the manafold this could have come off too, youll here a sucking of air sound!! but like ther other guys said Boost worx will rectify that!
cheers
AD
https://www.sau.com.au/forums/topic/117111-r33-problems/#findComment-2217920
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
