ok so its been said it can be done but you are confused to as how to do it, well no worries heres a short rundown of what to do...
remeber when using a rb25pfc on a rb20 you MUST upgrade injectors due to the r33 rb25det having 370cc injectors vs the 270cc injectors that came std on the rb20.
download the attatched pdf document, nevermind the fact that its for an r33 gts-t with an rb25det, the pinouts are the same for the rb20 except 2 pins.
on the pinout locate pins 112 and 114 on the ecu plug and carefuly using a small pin or piece of thin stiff wire remove these pins and swap them (you are swapping the triggers for injectors 4 and 6 around).
to do this you'll need to remove the clear ecu backing plug cover and then with the wire on the front side of the ecu there will be a small tab above the pin that needs to be bent back a bit to pull the pin out, i'll try to get pics later.
ok, now that you've swapped these pins start up the pfc and set the injector correction for what ever injectors you have, remember to install a resistor pack if you are using low impedence injectors...
if all went well when you crank the car it should start up and idle well on the first go, verify that afr's are good (which they should be as the rb25 pfc runs stuff silly rich...) and enjoy!
now go tune the car and terrorize r33 owners :O
RB25DET_ECR33_Pinout.pdf
Edited by carl h
https://www.sau.com.au/forums/topic/117123-using-a-rb25det-pfc-on-a-rb20det/
excellent post mate, you have given me hope with running one in my car now. someone said in an earlier post however that the firing order is different?
the link doesnt work also by the way.
Edited by SirRacer
put this on the DIY thread. i reckon it should be attatched to the "power fc frequently asked questions"... perhaps...:thumbsup:
thanks alot for that. should save me about 500 cos the rb20 pfc are that much more expensive than the rb25's.
cheers.
now go tune the car and terrorize r33 owners :)
So you swap the injecting timing, but not the ignition timing. Is that right?
:thumbsup: cheers :D
For sure I'd like to know if anyone has had success with this too. It would save all the RB20 guys lots of money that could be spent on, oh I don't know...... larger injector's maybe. :D
Anyway, super write up and I look forward to the pic's you were talking about and maybe you could fix the link to that pin out so we can download.
I'll be keeping an eye on this thread for sure! :)
Cheers :thumbsup:
perhaps, but if you are taking the car to a pfc tuner then they can copy the fuel/timing maps from the rb20 base map and put it into the pfc.
we did try this on one of my friends cars and it does indeed run fine...i'll see if i can get copies of the base maps from the rb20/25 and do some comparesons between the 2 but i doubt that besides where the vtc kicks in and out it wont be any diffrent...we'll see.
oh and heres a copy of the r32 ecu pinout for anyone caring to compare.
Sydneykid can you explain that comment, seems to have some merit behind it
I thought it was obvious, changing the injector timing (swapping 4 and 6) and NOT swapping the ignition timing means that the injector on #4 fires when the ECU is telling #6 spark plug to fire. I don't know about you, but that seems wrong to me. :P
Logic tells me that if you swap the injector timing you should also swap the ignition timing to match. ;)
Any information ... successfully using a gtr power fc in rb20 would be great
The usual question is 2 AFM's on an RB26 versus 1 AFM on an RB20. Simple answer is to just parrallel up the ECU inputs for the AFM signal. So the ECU thinks that there are 2 AFMs with exactly the same voltage output, which fine and dandy. If you use the RB26 PFC you can add an inlet air temp sensor and use the PFC correction map accordingly.
My own RB20 uses an RB20 PFC, which is now used on the RB31DET. If pushed, I would always use an RB26 PFC on an RB20 in preference to an RB25 PFC.
:thumbsup: cheers :thumbsup:
i dont think that, that logic is quite right.
firing order for all rb motors is the same no, and if it wasnt then you wouldnt be able to run a wasted spark setup on the motors wiring them the same way.
the only diffrence between the 2 ecu's is the vtc trigger, boost solenoid trigger, and clys 4 and 6 triggers being swapped other than that both carry the same exact pinout.
if i could get this picture of the r32 ecu plug to upload you would see what i mean...
we'll slap the pfc back on my friends car this weekend....see if we cant get video proof :blink:.
im hoping redtop and silvertop rb20dets are the same as im sticking in a rb25 powerfc in my r31 shitbox
it should b the same n all
if it dont work ill just use it on my r33 and sell that damn crapola microtech....
you wire it directly to the pinouts, bypassing the wiring loom
im pretty sure anyway. it makes sense, as they are on the pinout for the ecu connector, just not on the loom.
much like the airtemp sensor. the ecu has physical pin, but the loom doesn't
a bit off topic but what does the air temp sensor look like?
ive seen it on the rb26 but it would be nice to see what it physicaly looks like, i might try fitting one to my motor and seeing if the pfc will read it...
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
