Fallen victim to the cripling Nissan Stageas out there.
Flat bed truck reversed into my car this morning in the street, for a building works across the street.
.......happy but sad, at least I am going to get that DAYZ front bar now hopefully through the insurance company(need a new front bar anyways). Wont be able to get the parts anywhere by from Nissan either......
The damage is front bar support (which was custom done by revzone for my cooler), front 1/4 panel, front bar, front bar lip, front idicator (possibly salvagable), front driver headlight and front driver parker
https://www.sau.com.au/forums/topic/117129-crashy-mccrash-crash/
That really sucks! Sorry to hear it Alex, I really hate it when something happens to your car and you had nothing to do with it. If they can't drive without hitting stationary objects then I don't think they should be driving at all!
As far as insurance is concerend, it is a Dayz bar the has been damaged right? :thumbsup:
Alex,
Shizen Houzen.
Want the number of my Panel Beaters?
Tops Blokes.
Nunawading Panels
9873 5855
Tell you I sent you.
PS. Who's the insurance company for the person who hit you.
NEVER LET THEM TAKE YOUR CAR FROM YOU.
They will fix it in the cheapest possible manner and tell you its good enough.
Speak to Tony. He'll help you out with whatever you need.
that sucks mate, but at least you got all of his details
Alex, if you want a driver side qtr panel, a guy here in Kinglake West has got one, its silver
but is clean as
give him a call, might still have it 03-5786-5566 or 0418 123 637
a good guy and knows his skylines-
I am not after any parts thanks guys, just letting you all know about it is all.
The insurance company will cover all the costs, ive never thought this about any other car, but i shit everyone not but I can see this ending up to cost 7-10k after labour, parts etc...
Alex,
which insurance company is he with?
I repeat. DO NOT GIVE YOUR CAR TO THE INSURERS.
Get the quotes yourself, give them to the insurance company and make sure they go to your chosen repairer to asses to damage.
Don't go to their assesment places, as they often just take photos of the damage and ask panel beaters to quote on the e-mail, and then give the job to the cheapest, regardless of the work involved.
BASS OUT
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
