Heyaz
Any way a while ago i bought a pod filter and a adapter for my r32 gts-t type M and have just been looking for the time to make up a cold air intake box for it. But i have been reading and it seems that quite a few people running reasonably stock gear, havent bothered with the air intake box (although a couple of the people are running new turboes, injectors etc.) They just have the pod in the engine bay. So, a pod sucking in warm air, sucks enough in to make it better than the standard panel filter, sucking in cold air? I would prefer not to go to the trouble of making up the intake box for my pod, but i will if its worthwhile (cant afford to buy 1) If any one wants that re-worded just ask, im not so smart :O
Also is it worth putting some custom or aftermarket exhaust headers on it? It has a 3 inch turbo back exhaust, but standard exhaust headers. Am i likely to get less lag or faster spool or moor KW out of em?
Thanks, sorry about the annoying questions but i have looked around and cant really find specific answers to my questions.
you don't have to make a full box for it. just 1 wall to stop the hot air getting to the pod. i have a pod and i have a duct coming up from the intercooler pipe hole (i have a front mount so i have an empty hole) and i'm going to put the factory cold air snorkel back on and just have it sitting on the pod, and just make a single wall up to stop the hot air. that way i will have 2 sources of cold air.
http://img456.imageshack.us/img456/9962/r32carsm2ph.jpg
So lets say i had it hooked up like that, coming off the turbo, i would then make a heat shield (out of aluminium) going diagonally from the [wheek arch] to the side of the pod filter to block off rising heat from the engine, and leave the back and front of the pod open, with my standard cold air intake in the same position
right? or wrong
Edited by 32thrasher
yeah sort of. i have the standard intake, i just have a pod where the airbox was. go here http://www.uniqueautosports.com.au/ and go into parts catalogue, skyline gts-t, engine. then most of the way down the page there is a UAS cold air box. the pod sits in that. basically all you need is the vertical wall.
thanks so far, but another annoying question, what do you mean, have the factory cold air intake sitting on top of my pod? Do you just mean have the factory cold air intake, inside of the partition, facing the pods general direction?
Thanks for your help, so far :ermm:
the yellow line is about where you would put the partition, and the green represnts the top half of the factory airbox and snorkel.
the pod is under the green bit.
Edited by mad082
i'm having one of those days too. you'd probably want to make the partition out of a heatsheilding material rather than aluminium. any metal will just absorb heat and won't work as well.
you can get stuff for exhaust shops that works really well, but it costs a bit. but if you could get your hands on some high temp plastic, or a square of fibreglass, that would be ideal.
i'm going to make mine out of firbeglass and then go the the wreckers and get an old bonnet lining and put that in there for extra heat protection. if you do make it out of alloy i'd do the same.
r32's dont have a snorkel on top of the airbox like an R33 ...
the cold air intake comes from behind the passenger headlight and comes out of the guard into the airbox..
so yeah, might wanna consider that
So all your saying is if you have a R33 like me just buy the UAS fibreglass cold air box and keep the standard snorkel is that it?? wouldnt that just be pointless??? The air from the snorkel would not reach the pod in the UAS box.
heyaz, i just installed 1 of these things ( yet to add a partition for cold air) into my 32 gts-t and wow. I didnt think it would make any difference but the difference is huge. I dont know if the sensor just inside the intake had a loose wire or what but i added the pod and now i get my turbo spooling at 2800 rpm instead of 3000 rpm and it holds boost almost to 6000rpm at which stage it drops boost, instead of dropping .2 bar the second it hits 5000 rpm.
Makes the car sound a like its got a BOV or something, the pod noise is really damn loud. (not sure if im to keen on it)
thx 4 ur guide mad
Edited by r32 gts-turbo
nahh, just a pod and made a partition out of 2 peices of aluminium with some heat obsorbing material in between (split pins to hold the 2 pieces of aluminium together) a bit dodgy :unsure:
i wasn't saying buy a UAS one and leave the stock snorkel on. 32 thrasher didn't understand what i meant about a partition. what i'm saying is put a partition up and leave the factory snorkel. if you buy a UAS box you wouldn't use the snorkel unless u cut a hole in the box to feed it into. the problem with the UAS boxes is that if you have a stock cooler or a cooler that uses both stock intersooler pipes, then the box doesn't get very much airflow to it, unless you start cutting holes.
and i didn't know r32s didn't have a snorkel.
Edited by mad082
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
