a5h: a standard r33 gts-t does 0-100km/h in 6.18 & 14.4 in 0-400m.
if you take out the speed limiter, a standard r33 gts-t (rb25det motor) should pull approx 230km/h top speed.
if you add aftermarket exhaust off the turbo and an aftermarket air filter your times should be approx 5.8-5.9 for 0-100km/h and 14.0-14.1 in 0-400m.
A standard GTR, if it would be r32,r33 or r34 does approx 12.9-13.2 in 0-400m and a top speed of approx 260-280km/h i beleive (with the speed limiter removed)
  • 1 month later...
Originally posted by Sir R33
my car isn't limted to 180 it stops at 194!!!! and no my speedo isn't out i've checked that
Im not sure if my speedo is out but mine goes way past the 180km/h pin as well, atleast 190km/h (looks to be the same distance past the 180km/h as wher ethe 190km/h mark would be).
Thats pretty much flat in 4th and if you drop it back to about 175km/h and throw it in 5th it has just as much punch and wants to keep going.
I checked this out last thur. 7,200 in 4th (rev limit) is 198km/h. confirmed on my gps.
no sign of speed limit :D, 5th doesn't pull that hard at those speeds but I've done at least 215 without speed limiter.
stock except for 9psi boost.
i have a kakimoto ss exhaust. dump pipe, pod filter and running 11 psi of boost.
on the apexi rsm with g-force meter it records my 0-100 as 5.3 seconds. 1/4 as 13.5 and my top speed is 257 (the apexi rsm kept that) (i wasnt daring to take eyes off road). i set my speedo with a gps so it should be spot on.
no that would be a really technical way of doing it.
because the car has after market wheels and white dials in the cluster the speedo was over 10 kmh out. when i got the apexi rsm it allows me to fix this. so first up i sat on 60 kmh and corrected then checked at 100 and last off 150.
me smart like tractor
Originally posted by benm
Im not sure if my speedo is out but mine goes way past the 180km/h pin as well, at least 190km/h (looks to be the same distance past the 180km/h as where the 190km/h mark would be).
Mine is exactly the same in terms of pin position, looks to be doing 190km/h.
Originally posted by rs73
at your speed of said 190.... do you remember what's the engine rpm at 4th gear and 5th gear?????
I didnt look at the tacho on my first go when it hit the limiter [around 190 mark], but decided to do it again just to check rpm. Mine was in the area of 5,000rpm in 5th gear and still wanted to pull hard...until it hits the limiter of course...I can feel there is plenty more there, with the speed cut I think mine would get up around the 250 mark but the road / track would have to be very flat and long for me to try...felt comfortable at 180 / 190 :D
Hi Everyone,
I think you will find, the people who are hitting around 190 ish with the speed limiter are really only hitting about 180.. (if you have aftermarket wheels this will put it out) plus cars are always saying higher speeds than you are actually doing (factory cars)..
Take for instance some of the new porche's One said it was doing 320 (or something like that) but on the radar it was only doing 294kph... (this was out of a motor PCOTY magazine a few years back).
I though the Skyline in stockish form with out the speed limiter would get close to 240-250kph.
Well thats my 2 cents worth and feel free to correct me if I am wrong.
Regards
Rob
if u have wider wheels it will be out... but if the rolling diameter is the same should be fine.
Remember we are driivng jap cars - their speedos might actually be more acurate :)
Yeah i reckon max 240km/hr or so.. but remember kids: don't do this at home :D coz yeah, on a road its not safe.. if u kill yourself fine, but if you lose it and kill somebody else i'll hate you for eternity.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
