Car: MANUAL ER34 GTT
boost controller : dual stage Turbosmart
ok, i had it all wired up for low and high, low is set to 5psi, high was set to 9psi.
i had it dyno'd on the weekend, but we couldnt get boost to go past 9.5psi.
i was told by the tuner that i had it installed incorrectly... but when i installed it the way he suggested, i had unlimited boost (didnt matter if it was on low or high, or settings on the controller itself)
at the end of it i was pulling 172.3 rwkw on 9 psi.
my AFR were 14.5-8:1 on nice putter @ 100kms.. but under boost it went to about 10:1
its definatly not exhaust restriction because when i have unlimited boost i can hit 15psi.
picture shows how i THINK its wired up from memory
big help to everyone in advance!!
Edited by illusiVe
https://www.sau.com.au/forums/topic/117188-boost-controller-issue/
if anyone with a stock GTT and hasnt moved the stock T piece between the actuator, wastegate, turbo intake. etc.
if they can take a high res pic.. so i can attempt rewiring it.. it seems i have a tube or two left over.
as i was saying, i've also tried blocking off the tube coming from the ? (cant remember what thats from) and then just putting the boost controller between the Turbo and the wastegate (arrow points towards gate)
Edited by illusiVe
unplug the hoses to the factory solenoid DON'T UNPLUG THE WIRES TO IT...
and simply put your dual stage between it... easy!
I don't recommend you use the turbosmart Dual stage.. I had bad experiences with it... it spikes...
and that top hose in your diagram, thats goes to your intercooler piping man.. don't block it.. you need it...
Edited by johnnilicte
install the dual stage tee in between the actuator and the other tee that runs to the factory boost controller.
Leave the rest alone.
The factory wastegate is fairly soft so by removing the factory solenoid you will end up with a lower base boost setting that you have to make up for by bleeding more air via the dual stage.
Does the 34 still have the factory stepped low/high boost thing happening? If so then do a search for the factory boost controller mod that will set a constant boost level for more consistant results.
hey guys... just realised whats going on.......................... i think
I've forgotten how the stock setup goes for my GTT
could someone who does NOT have a boost controller show me factory wise the setup from the T piece, actuator, turbo, intercooler piping, wastegate.
if i simply put it between the turbo + wastegate i have unlimited boost (up to 1.1bar...furthest ive had my foot down), how i have it installed at the moment it works fine, can completely control boost... just not get it above 9.5psi
    • You would probably do a lot better in a claims process then most people. When I called the insurance company, they were surprised I read the pds because according to them almost no one does lol.
    • Yeah it should be, but I wouldn't be surprised if the insurance company tries to pull some argument out of their ass to avoid paying you out.
    • On some cars like MR2 Turbos they're notorious for not letting the wastegate open far enough to avoid overboost, especially certain cheap downpipes. If adjusting "percentage cycle" fixes it then it's just an electronic control issue, not a hardware one.
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
