Hey guys, just got a querie that I was wondering if anyone could help me with. When I got home from work today and parked in the driveway I noticed my oil pressure was reading zero! I tapped the accelerator and this brought it back up, but as soon as it started to ilde it went back to zero again. A couple of hours later I wnt back to the car, started it and it gave a normal pressure reading. However, I went for a drive and as soon as i stopped and the car was idling I got a reading of Zero (during regular driving I still get a normal pressure reading). It seems the only time I get a positive reading during idle is when I first start the car (does not matter if the car is cold or still a bit warm from its last run). Any ideas what this may be and how best to fix it? Id really appreaciate any help some of you more knowledgable folk could give me.
Cheers
https://www.sau.com.au/forums/topic/117221-loss-of-oil-pressure/
try changing the oil pressure switch. it should cost much from nissan.
do not mess with oil pressure, i.e. hoping the problem will go away.
or better yet, get an aftermarket oil pressure tester/gauge. these usually come with their own sensors which is what i'll be running on my car once its back on the road.
go to your mechanic and ask for a mechanical oil pressure check up, it should give you a true reading. if its reading fine on the mechanical gauge, get your sendor unit changed( it costs around 200 from nissan).
if its reading like that on the mechanical gauge as well, you are in serious trouble. it could be the oil pump or bearing.......
personally i think its your gauge, coz if its really zero oil pressure, you would start to hear some loud noise from your engine..., and its just a matter of mins before the motor is gone.
OK I just wnt through all of this with my car
At frist startup oil pressure was normal then as soon as it got some temperature it would go to nearly zero
I did the check with a mehanical guage and it agreed with the stock unit
Then I thought about my oil (Turbolight 10W40)
I changed it to penrite 10W60 and the problem was solved, Simply put the lighter oil could not take the heat and broke down as soon as the car got up to temp!
Thanks for your help thus far guys. I changed the oil and filter thismorning, but unfortunately it hasn't fixed the problem (oil was pretty crap though so still a good thing). The car is at the mechanic now so hopefully I'll have a better idea of what the problem is soon. Ill let you know the diagnosis when I get it.
I'm not sure if i can help,
Morning - Pressure up high because the oil hasnt circulated through the entire engine.
After driving for awhile - pressure will be regulated by where your foot position is (Or Revs).
When you stop and idle - because the oil is warm, it wont need a lot of pressure to circulate.
BUT those guages are farked in skylines. Try using another guage. I would only be concerned when the red light comes on.
-------------i think thats right
Got my car back from the mechanic. The problem was just my pressurs sensor, which will need to be replaced. For some reason it won't give a reading when the car is idling even though the pressure readings are normal (according to the equipment he used). Thanks again for your help guys it is much appreciated!
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
