That's it mate! You COULD just cut the hose and fit it in between but when I installed it on my R32 GTS-t, I replaced the hose with longer ones to enable me to mount it away from the turbo to somewhere accessable. This will also stop you burning your fingers off while adjusting the boost.
You will probably need to remove a few pipes to be able to access the actuator + turob and fit a hose clamp!
Hope that helps!
These are really good controllers and I have even considered going back to it from my EBC.
ahh hmmmmm, thanx ummm.. So then just to make sure of the location can you do me a big assed favour and circle the area, or the pipe or even just the area its in?
thanks hehe
http://img137.imageshack.us/my.php?image=p10101821nj.jpg
http://img137.imageshack.us/my.php?image=p10101812wy.jpg
Edited by r32 gts-turbo
Ha Ha Ha, glad to be of service!
First time I have heard that! But I guess we all have to start somewhere and from reading all the posts from the extremely knowledgeable I will always feel like a beginer (although I have been doing this for a few years now as a hobby!)
I like to be able to assist and teach from where others have tought and assisted me!
We BOTH have a long way to go my friend but shout out if you have any further problems!
hmm so i set about installing the thing today, but i have run into a problem. The hose from the actuator to the turbo is very short and therefore i cant even reach it to plug the controller in. I have sort of rigged up a extension for the pipe (using some clamps and a thinner piece of hose which i put inside, to connect the hoses) so that i can run more pipe off it but i cant get it clamped down due to having only about 2 inches to work with.
So ill have to pull the hose off at the turbo end. Unfortunately i cant get into the end close enough to pull the clamp or the pipe. I can reach it with a screwdriver but the actual end will need some pliers and only has about an inch and a half of space. any suggestions? can post pics if needed.
yeh i have the hose, i was just trying to figure out how to hook it up. ended up putting slightly smaller hose inside the other hose to connect the 2 pieces of hose, with some clamps. The controller was adjusted rather high when i put it in though, it boosted to like 1.2 bar, ouch. Now time for the fine tuning, thx
Hey Mate, I would suggest using a metal joiner in-between the hoses if you must do it that way!
For all this mucking around you could have just removed some more pipes to be able to get to it! I just removed and refitted my turbo for the second time tonight so I know how it can be a pain but it will be rewarding when it is done!
  • 1 year later...
Yo just throught i'd bump this old topic instead of making a new one, my turbotech controller that i'll be putting on the gtr just rocked up and i popped the bonnet and looked around confused... Where do i T- Piece it? I am assuming it would be off something on the left side of the engine heading into the inlet manifold correct? Anyway tried to search for an rb26 tap install but couldnt find 1
Just want to run 12 psi and hopefully get a bit more torque
The turbotech is really good for the price..you'll love it.
Ummm, have you had any luck? It's pretty simple when you undertand where it needs to go. Try the search function to locate pics. If you need rubber hoses they're dirt cheap from places like SuperCheap.
Good luck.
It's easy enough on a GTS-T but the whole GTR thing confuses me, i don't want to run it off a hose and only have control for 1 turbo, am trying to find a hose after the cooler to put it into
That link is useful for gts-t, but i'm too dumb to understand what you've ssaid without pics mike hehe
I think i confused people by bringing up a post about a gts-t and asking for help with my gtr lol :nyaanyaa:
I've had a few workshops tell me it comes from near the inlet manifold so cops probably won't discover it
Pic enclosed now, would this be it?
Edited by GTAAAH
Dude you plumb the valve into the hose leading to the wastegate actuator/s.
Just follow this turbosmart guide:
http://www.skylinesaustralia.com/forums/ip...load%26id%3D171
Scroll to the bit about twin turbo setups.
Let us know how it goes
Edited by R338OY
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
