That's it mate! You COULD just cut the hose and fit it in between but when I installed it on my R32 GTS-t, I replaced the hose with longer ones to enable me to mount it away from the turbo to somewhere accessable. This will also stop you burning your fingers off while adjusting the boost.
You will probably need to remove a few pipes to be able to access the actuator + turob and fit a hose clamp!
Hope that helps!
These are really good controllers and I have even considered going back to it from my EBC.
ahh hmmmmm, thanx ummm.. So then just to make sure of the location can you do me a big assed favour and circle the area, or the pipe or even just the area its in?
thanks hehe
http://img137.imageshack.us/my.php?image=p10101821nj.jpg
http://img137.imageshack.us/my.php?image=p10101812wy.jpg
Edited by r32 gts-turbo
Ha Ha Ha, glad to be of service!
First time I have heard that! But I guess we all have to start somewhere and from reading all the posts from the extremely knowledgeable I will always feel like a beginer (although I have been doing this for a few years now as a hobby!)
I like to be able to assist and teach from where others have tought and assisted me!
We BOTH have a long way to go my friend but shout out if you have any further problems!
hmm so i set about installing the thing today, but i have run into a problem. The hose from the actuator to the turbo is very short and therefore i cant even reach it to plug the controller in. I have sort of rigged up a extension for the pipe (using some clamps and a thinner piece of hose which i put inside, to connect the hoses) so that i can run more pipe off it but i cant get it clamped down due to having only about 2 inches to work with.
So ill have to pull the hose off at the turbo end. Unfortunately i cant get into the end close enough to pull the clamp or the pipe. I can reach it with a screwdriver but the actual end will need some pliers and only has about an inch and a half of space. any suggestions? can post pics if needed.
yeh i have the hose, i was just trying to figure out how to hook it up. ended up putting slightly smaller hose inside the other hose to connect the 2 pieces of hose, with some clamps. The controller was adjusted rather high when i put it in though, it boosted to like 1.2 bar, ouch. Now time for the fine tuning, thx
Hey Mate, I would suggest using a metal joiner in-between the hoses if you must do it that way!
For all this mucking around you could have just removed some more pipes to be able to get to it! I just removed and refitted my turbo for the second time tonight so I know how it can be a pain but it will be rewarding when it is done!
  • 1 year later...
Yo just throught i'd bump this old topic instead of making a new one, my turbotech controller that i'll be putting on the gtr just rocked up and i popped the bonnet and looked around confused... Where do i T- Piece it? I am assuming it would be off something on the left side of the engine heading into the inlet manifold correct? Anyway tried to search for an rb26 tap install but couldnt find 1
Just want to run 12 psi and hopefully get a bit more torque
The turbotech is really good for the price..you'll love it.
Ummm, have you had any luck? It's pretty simple when you undertand where it needs to go. Try the search function to locate pics. If you need rubber hoses they're dirt cheap from places like SuperCheap.
Good luck.
It's easy enough on a GTS-T but the whole GTR thing confuses me, i don't want to run it off a hose and only have control for 1 turbo, am trying to find a hose after the cooler to put it into
That link is useful for gts-t, but i'm too dumb to understand what you've ssaid without pics mike hehe
I think i confused people by bringing up a post about a gts-t and asking for help with my gtr lol :nyaanyaa:
I've had a few workshops tell me it comes from near the inlet manifold so cops probably won't discover it
Pic enclosed now, would this be it?
Edited by GTAAAH
Dude you plumb the valve into the hose leading to the wastegate actuator/s.
Just follow this turbosmart guide:
http://www.skylinesaustralia.com/forums/ip...load%26id%3D171
Scroll to the bit about twin turbo setups.
Let us know how it goes
Edited by R338OY
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
