So my mate went to the BP servo to fill up.
long story short he accidentally pumped about 2 litres of unleaded instead of premium (ultimate).
he freaked out and then started to fill the rest until full with premium.
will the 2 litres of unleaded affect his car at all?
i said it wont but he wont beleive me so i thought i should ask you folks...
what do you think??
Hey guys probly a stupid question but do all skylines have to run on premium? :| damn thats gona kill my wallet!!! What about 180sx's ?? Cheers
Yes if you want to drive them.
They will detonate with lower octane and higher boost.
Its funny that the guy is worried about 2L of low grade in a tank of premium. If the low grade is 91 octane and high is 98 then it works out at about 97.75% octane. Worry? i think not.
not just all turbo skylines, all turbos.
My understanding is you can take this as a general rule: Any petrol engine with forced induction or high compression ratio (say 10:1 or higher) needs high octane fuel to stop preignition of the fuel, which can potentially damage engine interals.
There are a few exceptions - the Honda Jazz runs something like 10.8:1 compression ratio, but still accepts regular unleaded. But as a general rule, it works.
Edited by Big Rizza
Well there are a few more that are cracking the 10:1 barrier with standard unleaded now. I know the new BF Falcon 6's (not the turbo's though) are running higher than 10:1 not sure about others, but it shows that it's possible with the right engine & tuning.
The manual I was given for my R33 says "Unleaded fuel with Research Octane Number 91 or higher". Does anyone have a manual that says otherwise?
If the manufacturer says 91, then whats the prob? Surely they wouldn't tune them for 98 and then advise running 91...
By the way the only thing that's been done to mine is exhaust. Boost is stock.
from what ive heard, Japan have better fuel? but either way, like Flipmo and GorGasm said, it is better if you run a (newer) turbocharged on a higher octane level. 95 or 98 RON.
Just wondering, how much is it for premium at the moment say...... in Sydney? Or Brisbane?
Yeah I'm just trying to save some money here, if possible... Even running 95 would save a bucks at the pump.
98 is about $1.40-1.50 atm in my area (south Sydney).
Bugger all. I wouldn't bother using anything higher than 95ron in a non turbo skyline. Anyone wanna argue with me?.
In fact I drive an R32 gts-t, and I only use 95ron the majority of the time.
I do live in a cool climate though. During the summer, or when I plan on giving my car a bit of a hard time, I always run 98ron.
You wouldn't believe how many people at my work put permium in their diesels thinking it's diesel.
Now thats no good.
i put 15ltr of diesel in a turbo cefiro on the way home from the docks once...what a farkin mess that was ..can still taste it :thumbsup:
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
