Hey all!
I know this topic has come up before, and I have read them all, but I just need to clarify how would you know
if the ATTESSA-ETS system is working at optimal performance when you buy an R32 GTR?
What would be the signs of a healthy ATTESA-ETS system?
What would be the bad signs of a ATTESA-ETS system that is not working properly?
Cheers guys!
https://www.sau.com.au/forums/topic/117257-r32-gtr-attesa-ets-testing/
Well its easy to tell if the system is all OK, if not the ATTESA light will be on on the dash.
However its much harder to tell if it is really healthy, because even if the system is working fine the centre clutch packs do wear, the system will think it is giving front torque but the actual torque transmitted might be minimal.
If you get the car dynoed in 2WD, leave the dyno unlocked and re-install the fuse and try and drive off the dyno.
If the clutch packs are in good nick, the car will drive straight off. If they are worn or slipping, it will move off more slowly (or not at all).
A subjective test I know, but if the dyno operator sees a lot of GT-Rs, he'll have a pretty good idea.
That's good advice: I'll give it a try!
What wbout the torque gauge? If the needle is slow to pick up when you give it a bit, couldn't that be a sign of an unhealthy attesa system?
I heard a healthy system, snaps the needle quite fast to full front torque load under max rear slippage.
What are your views on bleeding the attesa-ets system? I have heard that corrects many of the problems associated with no or low torque conversion to the front.
How do you know when your clutch packs are wrecked?
All opinions welcome!
Edited by skylimit
Well if the torque gauge is moving slowly that suggests that it is not bleeding or the clutch packs....the gauge reflects what the system is trying to do.
Maybe your longitudinal accelerometer is failing? I've not come across that problem but it must be possible/
The torque gauge actually has nothing to do with the mechanical side of the system. A completely stuffed transfer case will not be indicated by a lazy gauge, as the gauge signal is derived from an electrical output of the ATTESSA ECU it will still work, and should not be relied on.
We use a 80psi pressure gauge on the hydraulic line feeding the transfer case to make sure at least 50psi to 70psi (will vary depending on load) is present when front drive is operated. If this is ok then the transfer case is the problem (clutches worn or hydraulic actuator failure).
Hope this helps. :laugh:
Hope this helps. :)
hey paul do u happen to have a pic of how u plumb in a pressure line off the main hydraulic line??? sounds like a damn good idea and worthwhile as i dont even have a torque split gauge in mine (stagea).
its a simple matter of installing a "T" fitting at the rear of the box where line attaches or getting Pirtek or any other reputable hose doctor to install one in the line and cap it off when not in use.
paul is 100 % correct and its the only real way to test it properly.
hey paul cheers for that, so a regular oil pressure guage will be fine with a 0-100psi readout or does the pressure go higher than 100psi?
also on the r32 system vs the later model ones that hold the pressure..
does that mean the r32 gtr would read 0 psi when not operating 4wd and r33 and 34's would still have how much pressure when in 2wd?
Edited by CruiseLiner
Yes a 0-100psi gauge will do the trick. As for holding pressure on the later models....its the preload on the clutch plates in the transfer case not the pressure applied to the ATTESSA hydraulic actuator (rear of transfer case) that is the problem on newer models (this is why you cannot dyno R33 + R34 models in 2 whell mode without removing driveshaft). You should have 0psi pressure when in 2wd mode.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
