hey guys,
my 'line is running an APEX'i Auto Timer and an aftermarket alarm (not sure on the brand -_-') the problem is, if i forget to wait for the timer to run down and the engine to shut off before arming the alarm, then it sets off the alarm when it does eventually turn off. it's probably a really easy fix but i'll be buggered if i can find the cause.
any ideas?
https://www.sau.com.au/forums/topic/117290-turbo-timer-interfering-with-alarm/
hey guys,
any ideas?
Have a look in Fast Fours Magazine Security In Motion have an alarm with a turbo timer built in so you can have your alarm on while the turbo timer is still running and your car is safe from the time you get out and press the remote. Good value too.
http://www.skylinesaustralia.com/forums/in...howtopic=106206
Your problem is easily fixed.
Any Alarm will hook up to a turbo timer.
You need to get a 12v 5 pin 30amp relay. Dont go to Dick smith, they often sell cheap lower voltage relays to you. Go to a reputable place Repco or somewhere.
Repco Sell narva Relay's these are the best
to wire the relay to the turbo timer
- turbo timer (your wiring color will vary depending on model of timer)
- Constant 12v - to an uninterupted 12v source - make sure you use a fuse
- Accessories - helps to set the timer
- Earth - a clean metal part of the car
- Ignition - runs the car when key off
- Park brake arm - Ground sensor - connect to parking brake to arm turbo timer
Relay wiring ( cut the cars ignition wire)
30 - Engine Side of ignition wire
85 - Ground
86 - Key side of ignition
87 - Ignition input of alarm
87a - turbo timer igniton feed
You will also need to use a diode between pins 87a and 87 with the line on the diode facing ( on the same side as ) pin 87a.
Let me also give you a few tips on how to make your car more secure.
1 - Hide the LED - this lets the theif know that you have an alarm and they come prepared - take them by surprise every time
2 - hide the valet switch
3 - keep your keys in a safe place
4 - make sure your installer is qualified and reputible. An alarm is only as good as its instalation.
5 - dont tell people ( not even your mom) what sort of alarm you have. Dodgy people down load all sorts of things from the internet
6 - dont leave valuable's cd wallets etc in plain site
7 - at night park under lights
8 - when you are going to get a park somewhere turn your system down a few blocks before you get there - dont advertise that you a something worth stealing
9 - tinted windows - great for keeping out peeping eyes
There are other things that you can do to a car to make it harder to steal, not impossible, but harder. However due to the nature of wiring specifics or instaltion techniques i will not post this information on such a public forum or PM it to you. Sorry but nowadays you dont know who to trust.
Regards
I couldnt be bothered tying it again, this is the std alarm/tt interface relay. Should do the trick
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
