I had nearly dry tank today and went to fill up a full tank at this BP servo... I figured it could easily take in about 60 litres... it came up to about 46 and then the petrol spilled onto my car and my runners (f**k i hate when that happens)... are u all sure it has 65? Or can the needle go past the lowest mark and still drive for another 5-10 litres?
To add more shit to the story the guy at this servo seems to have a pole up his ass, he called me a "water waster" for spraying the water onto my car to remove petrol stains saying "it wont do anything", then had a go at me for not using my credit card properly... really rude asshole to tell u the truth... I mean he was aussie and not some indian guy who usually man these servos... i can see the "fun" in working late night hours in that shit hole... but seriously he looks like he needs to find another job...excuse my rant..
By the way its the BP on Bell St Pascoe Vale...across from Maccas.
https://www.sau.com.au/forums/topic/117291-r33-fuel-tank/
DUDE same here..
Everyone tells me thats its a 60L tank or something..
Must be a s2 thing maybe?? smaller tank=less weight.. ahahah..
I havnt filled up past 50ls in ages, due to prices..
But i remember ages ago, i filled up to about 46ls and i couldnt go any further so i thought i still had about 10ls left, but the guage was nearly empty..
Edited by siddr20
https://www.sau.com.au/forums/topic/117291-r33-fuel-tank/#findComment-2166224
Sorry pplz...my bad.
It is a 60L tank. (GTR -72Ltr)
Which means that i can sqeeze more out of my tank than i thought....Always used to fill 42 odd litres; meaning that i actaully have another 18Lt to go!!!
The weird thing is that my needle reads Empty at that stage...but from what i read up top you can actually go past that!
Edited by R33_STEALTH
https://www.sau.com.au/forums/topic/117291-r33-fuel-tank/#findComment-2166691
I've heard that most Skyline fuel gauges are crappy and don't read properly anyway.
Mine won't even register usage untill about 150km's on the odo and is very random in it's readings. Lowest I've let it go was down to 3L remaining. Funny thing was, even at that level I had no light come on.
https://www.sau.com.au/forums/topic/117291-r33-fuel-tank/#findComment-2167169
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
