  • Replies 48
coilvers are a whole strut/srping replacement.
basically its a perfectly match strut and spring, but all gives you things like hieght adjustment, damper adjustment(how hard/soft the bounces are) and high end ones give rebound adjustment too (how much it bounces)
personally, id reccomend the D2's for a good cheap street coilover.
teins are quite stiff, however they have just released a 'softer, australian version' they are still quite expensive.
ive got teins in my car, whilst it handles like a dream on flat surfaces, find some bumps like a normal road and it can be quite a handful.
ask wilkys what they reccomend coilover wise for a street driven 2 (i assume you dont take it to the track much, if at all) and get a price off that.
getting springs may be all you need, i dont know how 'hardcore' you want to go with your car(track/street/show?) but coilovers are definately a good handling mod.
https://www.sau.com.au/forums/topic/117295-permits/page/3/#findComment-2397033
my car was used for a bit of drift over in jah-pan.
so it came with alot of adjustable goodies.
coilovers are a good choice if thats your plan, but then you can always get the springs, and sell them at a later date for a setof coilies.
https://www.sau.com.au/forums/topic/117295-permits/page/3/#findComment-2397041
dude dont waste 600 on suspension that your just gonna replace soon just fork out extra and get some d2s the are about 1500 1700 fitted they are alrite coilovers i got them on my car i got the track ones u can get street, rally, and drift ones pretty much all at the same price u can adjust the dampener and hieght which is quite kool and if need be you can raise the car like a 4x4 or dumped in the gaurds (like me not good only good for shows bad scrapage in normal daily use)
https://www.sau.com.au/forums/topic/117295-permits/page/3/#findComment-2397547
Call them up and ask. Speculating isn't going to get you permits.
Since I have been over the pits a few times already, the dude has said
"You are not getting this car on the road with out permits for: ... ... ... ... ... ... ... "
https://www.sau.com.au/forums/topic/117295-permits/page/3/#findComment-2432532
Hey i just rang up the licensing centre regarding legal wheel widths and apparently theyre a bit flexible on the width just as long as the track distance doesnt change more than 25mm. So if i get some wheels with the same offset as the factory wheels my track distance should stay the same regardless of the wheel width, right?
https://www.sau.com.au/forums/topic/117295-permits/page/3/#findComment-2438314
    • I also understand psi but apparently most things make more sense in kpa oil pressure being one of a few exceptions so im trying to learn ahahahah, I have no idea of the relief spring pressure tbh I thought 110 which is the absolute peak it hits was about right, I was thinking of removing the relief and making sure it is in good condition, I would just replace it but couldn't find a replacement for an n1 pump too easily but I could just be blind.
    • It certainly does make sense that there is just no oil to pick up, but I can go 3 or 4 gears of WOT and have no oil pressure issues too (I have no logs of this unfortunately) and I have a fair amount of oiling mods to try and help only thing I'm missing is a rear head drain which is potentially the most helpful.
    • speaking of the relief spring and noting this is one of those stupid times where I understand imperial (psi) but the graph is in metric (kpa), it looks like the oil pressure is a little low at full noise too, isn't the relief spring 120psi/830kpa?
    • No. All these dirty old Datsuns are shitboxes. Including the GTR.
    • Yeah well I was thinking...there is nothing that happens when you get off the throttle that should cause low oil pressure, its not like clearances suddenly change or and the relief spring would close and in any case the sensor is on the feed side....so more likely there was no oil available to pick up which means all the basic oil control stuff to: 1. keep oil out of the head (restrictors) 2. get it back out of the head when it gets there (external breathers/oil return, drilling out the block and head oil returns) 3. have more oil in the sump to pick up - larger capacity sump 4. have more oil near the pick up - baffles
