Just Jap is pleased to continue to bring you the biggest selection of genuine OEM and aftermarket performance parts for your high performance Japanese import vehicle, as the best prices available.
We have a massive range of parts in stock in our Sydney warehouse ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
NISMO HEAVY DUTY ENGINE MOUNTS - RB26DETT (R32 & R33 GTR)
$120 EACH
GATES TRIPLE STRENGTH TIMING BELTS - RB20/RB25/RB26
$99 EACH
GENUINE NISSAN GTR N1 OIL PUMP
$499 EACH
GENUINE NISSAN GTR N1 WATER PUMP
$360 EACH
OS GIKEN ADJUSTABLE CAM GEARS - RB20/RB25/RB26 (Sold as a pair only)
$399 PER PAIR
TRUST CLEAR TIMING BELT COVER - RB26DETT
$150 EACH
TOMEI RB26DETT METAL GASKET KITS (Various bore and headgasket size combinations available)
Each kit includes:
Tomei Metal Head Gasket (Choose your bore size and required headgasket thickness)
Tomei Metal Exhaust Manifold Gasket
Tomei Intake Manifold Gasket
Tomei Throttle Body Gasket
Tomei Upper Oil Galley Restrictor
$750 PER SET
CP FORGED PISTON KITS - RB20/RB25/RB30/RB26 (Available in various bore sizes)
$1499 PER SET (Including rings and Gudgeon pins)
JJR ENGINE DAMPER KITS - SKYLINE R32 & R33 GTS-T/GTR (Bolt on fitment)
$99 PER KIT
NISMO CLEAR INDICATORS - SKYLINE R33 GTR & GTS-T
$125 PER SET
GENUINE NISSAN 400R CLEAR FRONT INDICATORS - SKYLINE R33 GTR
$320 PER PAIR
JJR STRENGTHENED REAR UPPER ADJUSTABLE CONTROL ARMS - R32 GTS-T
$149 PER PAIR
JJR STRENGTHENED REAR UPPER ADJUSTABLE CONTROL ARMS - R33 GTS-T
$149 PER PAIR
So how do you place your order???
The answer is simple!
Visit our website at www.justjap.com and purchase your performance parts online quickly and easily via paypal or credit card, or drop by our Kirrawee factory and pickup your bits over the counter.
Please contact [email protected] if you have any questions, or reply here.
Will most probably call up and get the Gates Timing Belt off you...
Any chance that there is a Damper Kit for a R34GTT?
Thanks
S
Hi Satanic, you can either order over the phone or online via our website :thumbsup:
Regarding the engine dampers, we dont have a specific model available at this stage for R34 GTT.
Cheers,
Steve
Thanks for all the orders guys, we have plenty of stock available
Purchase your parts online for speedy delivery around Australia.
Cheers,
Steve
  • 3 weeks later...
I am gathering parts to replace timing belt and water pump on my RB20, my question is about the triple strength belt, what makes it triple strength and how do they compare to genuine Nissan ones??
  • 4 weeks later...
Hi mate, sorry for the late reply
The Gates triple strength belts are constructed from high strength glass tensile cord which increases its performance and reliability. The belt’s heat resistant elastomer gives increased protection against cracking, and a specially modified jacket material gives the belt increased tooth strength.
We carry these in stock all the time for RB/VG & CA engines.
Cheers,
Steve
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
