Hi,
Just did a full services yesterday,
also changed the spark plugs to Iridium BKR6EIX
and in the morning, Start the car,
the car missing really bad, its feels like its runing on 5 cyclinders.
Drive for a while when the temp goes to the midle,
the misses reduces.
So i went and put back the old plugs, everything seems fine.
my mods are R34 IC, full exahust, POD, and boost to 11psi.
isthis common for carmiss fire when plugs regapped?
any comments appreciated!
Cheers,
I believe the original gap was at 1.1
I regapped them to 0.8
I thought it was the coilpacks, but took them out and tested them,
they seem ok!
I will try and put the 0.8 gapped back on again,
double check, see if it does the same thing.
if it is, then 0.8 is not suitable for me at the moment.
it wont work if you take them out and test them. as the current has nowhere else to go but to the thing your testing it with, where if its in your motor, you'd see it hitting your head. thats if its your coils.. it could be your CAS, afm's etc. anything to do with your timing.. its really just a process of elimination.
clean the inside of your coils with some steel wool or lightly with a dremil drill and see how you go.
just for comparison.. my plugs are gapped at .65.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
