What's the bodykit on this monsta?
Check this car up 4 auction out
Looks like a track car with all that widebody modifications, and allt he rollcages n stuff. Looks like its had a rear corner collision cos a chunk of the bodykit is missing on the bottom rear spoiler.
Mmmm looks vey nice. Wouldn't mind gettin that on mine :P (well if I ended up makin it any faster)
lol omg that is the m's factory r32... well it looks like they've taken all the stickers off it. Coz even the wing is the same. Its in one of the drag video's I got. Looks exactly the same, but the wheels are different.
http://www.ms-factory.co.jp/democar.htm
Man, the stickers are in the same position and stuff as well... either sum1 made a real good replica or that is the real car... which means that's the M's Factory Drag SPL.
Fromt he website...
BEST TIME 9.140 sec
ENGINE
Camshaft TOMEI IN and EX280? 11.5 Cam cap volt/bolt
Cybernetic Anthropomorphic Machine professional ket HKS all aluminum cybernetic Anthropomorphic Machine professional ket
Valve STD
Valve spring TOMEI RB26hiDoubles pulling
Valve guide M ' S FACTORY phosphorus bronze (milling)
Seat ring ARM 50 alloy
Cylinder head M ' S FACTORY SPL port processing, combustion room processing and water jacket processing
Head gasket TOMEI 87 ƒÓ 1. 5mm grommet
Cylinder head bolt TOMEI strengthening cylinder head bolt
Piston TOMEI 86.5 cooling channel attaching titanium top
Connecting rod HKS H section
Crankshaft HKS full counter crankshaft
ƒƒ^ƒ‹ ƒjƒXƒ‚ strengthening metal
Crank pulley - HKS
Oil pump TRUST
Water pump STD
Oil pan TRUST
Timing belt TOMEI strengthening timing belt
Plug HKS racing Pro 10th
Fuel tank ATL 11.6 liter
Fuel pump BOSCH 044 x 2
ƒtƒ…[ƒGƒ‹ƒŒƒMƒ…ƒŒƒ^[ $$ln PAXTON
Fuel delivery flexible pipe TOMEI
Injector SARD 1000cc x 6
Surge tank M ' S FACTORYSTD reforming
Throttle body Infinity 90 ƒÓ
Air cleaner HKS funnel
Turbine HKS T51R? SPL
EX manifold HKS SUS
West gate HKS GT
Muffler M ' S FACTORY 100 ƒÓ Titanium
COOLING
Intercooler TRUST 3 layer
ƒ‰ƒWƒGƒ^[ $$ln M ' S FACTORY caloric rise
Headlight TOMEI headlight intake
POWER
Transmission HKS Ver ‡U
Clutch HKS triple plate
Diff. F CUSCO RS R TOMEI ƒeƒNƒjƒJƒ‹ƒgƒ‰ƒbƒNƒX 2way
Drive shaft F HKS strengthening drive shaft R STD
Transfer M ' S FACTORY strengthening transfer DRAG SPL
BODY
Body reinforcement Section spot increase
Body kit M ' S FACTORY R32 body kit
Hood M ' S FACTORY carbon hood, carbon general-purpose duct
Glass M ' S FACTORY ƒAƒNƒŠƒ‹ƒEƒBƒ“ƒhƒD $$ln
Door mirror MATSUSHOU
INTERIOR
Seat RECARO SP? G
Roll bar For CARROSSE SAFETY21 7PJ section race/lace
ƒ[ƒ^[ HKS boost gage, TRUST oil temperature gauge, oil pressure gauge, temperature gauge and nature pressure meter
CHASSIS
Shock absorber - M ' S FACTORY (ƒI[ƒŠƒ“ƒY reforming)
Suspension MERWEDE F5.8 R4.8
Tension rod M ' S FACTOR Y tension rod
Front upper arm M ' S FACTORY drug upper arm
Rear upper arm JIC
Rear arm M ' S FACTORY pyro arm
Rear member M ' S FACTORY full rigidity
Front brake Black line slit rotor
Wheel ADVAN RG 9. 5j? 17
Tire NITTO NT555 275/40? 17
J-Spec!!! Import it for me!!! lol
if the back was smoothed out a bit, then it'd look the bizness...
found the website for the kit (and yes that includes the rear wing and bumper sticker lol no wonder they looked the same)
http://www.ms-factory.co.jp/partsdown.htm
Translated version: here
Altogether the kit costs 475000 Yen which is about $6,615 the car was sold for 500000 Yen
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
