http://nissanking.cjb.net
Car is for sale!! Easy 10s. Does 11.5 @ 124mph street trim.
323rwkw. RB30ET. Lotsa work
Currently defected and doesn't intend on getting the Defect off. Put the Rb30 back where it belongs in the R31 and buy the on @ http://nissanking.cjb.net for $12,000!!!!
ONLY 12G's! For a FULL CAR! no expense spared on this baby!
12G for everything except stereo!
You'd be stupid not to buy it!
PM me and I can get you some contact details if you are interested!
HI Fast 31, RB30 bottom end, JE forged pistons and Carillo conrods, Nismo bearings, o'ringed block with RB26 top end, 264 degree camshafts, adj camshaft pulleys, ported head with matched manifolds, valve springs, 6 into 1 exhaust manifold, Garrett GT3040 turbo, Progate wastegate, Trust 600X300X115 intercooler, TiAL BOV, Apexi Power FC, PWR radiator, 3.5" exhaust, alloy pulleys, enlarged sump, OS Giken twin plate clutch and flywheel.
Has 484 rwhp at 1.2 bar and cost $15K with a mixture of new and used parts. Bottom end will support 750 bhp and engine could easily make more max power, but would sacrifice driveability and throttle response.
Hope that helps
Yea you are hearing right. 11 second quarters (any day of week), 323rwkw, 12k. DEFECTED though.
Ideal for a conversion, R31 or VL, gemini even. It's currently in a MR30 skyline.
If you could get back to me DaBigBolf asap that'd be good If you might know a buyer so I can get hold of the owner and maybe organise something.
Car is in adelaide.
Yea it was in ZOOM a while back.
Time isn't important when you're gonna hav 300+ rwkw!
you think 190 is good fun Nismoid!!!! Drive this thing!
Snaps sideways in 5th. Has all the torque of the standard Rb30 too.
Make him an offer at [email protected]
He's desperate as to sell it!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
