Do you have an aftermarket fmic?
If not, i would advise that you stick with your factory air box as it will draw cooler air than an air pod. Just put a good high flowing filter in it.
If yes, you may have one of the factory ic holes without any piping going through it. I cut this hole to make it wide enough to fit a 4in drain pipe, coming from the front of the bumper. I then put a custom partition to prevent any hot air being sucked in by the pod.
https://www.sau.com.au/forums/topic/11740-cold-air-intake/#findComment-205541
