Last week i got my Blitz Intercooler and i thought the piping came polished, to my disappointment it didnt and the finish looked very ordinary.
Below is a pic of the piping AFTER i sanded it back with wet&dry and gave it a buff. Just interested what you guys think, and if anyone would like me to do theirs for them.
Or plenum etc
Just out of curiosity how much does this usually cost to get done in a shop? I want to know what i saved doing it myself.
https://www.sau.com.au/forums/topic/117409-polishing/
i like it.
When you sanded it back what grade of paper were you using?
Also for more coarse surfaces like crossover pipe/plenum.should a more coarse wet/dry paper be used to penetrate?then get it smoother with the smooth stuff then buff??
When they bent the pipe the outside 'stretched' and went all rippled so i had to start with 600 grade paper, then move up 800, 1000, and finally 1200. Took a while to get the bumps out. but yeh you need to get a smooth flat surface before you start with the finer stuff otherwise it will take you weeks to get any results with 1200 grade paper, then if you have access give it a buff to make it nice and shiny. If you live in Sydney i can probably give it a quick buff for you.
https://www.sau.com.au/forums/topic/117409-polishing/#findComment-2191123
Thanks for the offer,but i allready have a buffing kit.:P
Thats the sort of thread im after.:)
https://www.sau.com.au/forums/topic/117409-polishing/#findComment-2201628
It's a pritty ensane friend, when i first saw it i sent it to all my mates who woudl be interested in this thing and had the email topic
"Someone needs a girlfriend"
HAHAHA alot of time must of went into it cuase he says i spent 4hours on one little section or somthing. LOL
Crazy, but excellent end result!
https://www.sau.com.au/forums/topic/117409-polishing/#findComment-2201940
Excellent link... has just given me some more ideas... made my attempt look shit though :)
Ahh well back to the workshop!!!
https://www.sau.com.au/forums/topic/117409-polishing/#findComment-2207182
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
