Hi guys,
Can someone please help me?
Basically, from what I understand, the door sensors on the r33 are on different circuits. i.e. when the driver's door is opened and the key is in the ignition, there is a chime noise. But, when the passenger door is opened, there is no chime noise.
If i'm hooking up an alarm, how can I get it such that if either door is opened, the alarm will be triggered? i.e. where can I tap into a wire?
The reason I ask is because my alarm installer did a dodgy job.
https://www.sau.com.au/forums/topic/117416-door-open-sensor/
Hi guys,
Hi mate go to the thick wiring loom in the drivers kickpanel (to the right of your left foot) and find a thin red wire, it is one of 2 and it is the thinner one out of the 2, you can tell because the other one is a little thicker in diameter.
I have been fitting car alarms for Security In Motion for the past 5 years and if we don't know nobody does!
Next time just call us.
Can you explain something to me?
The previous alarm installer just soldered a wire onto the actual switch on the driver's door. But as I said above, the passenger's door is on a separate circuit.
So just to confirm, doing this red wire will have it hooked up to both sensors?
Cheers
To Confirm in a r33 the door sensor pick up wire is the thin red wire in the drivers kickpanel.
And as how that has been done, i have to repeat myself
It sound like your car would be fairly easy to steal.
Why?
Well not because one door does not trigger the alarm. But because the original installer obviously had no idea what he was doing. The r33 uses one wire to sense both doors opening, so having only one working means that installer -
- did not have much skill
- does not know skylines
- has probably left the alarm box in your kick panel or just under the dash
- was working to a price
I think what you should do is have a look under your dash, drivers kickpanel to see if you can see the alarm, if you can, dont bother taking it back to your original installer, take it to someone who knows what the are doing and get the entire alarm relocated and rewired.
Sure its extra money, but really from what you have said, it would most likely take less than 30 seconds to steal your car at the moment.
If you are looking to get it done fire a PM at CHRIS ROGERS, he is the man with the install contacts.
no it doesn't.
depending on car they are two different leads in two different spots.
32,33,34 &35 are diode isolated from the drivers door. all have two places to get the wire. I do not get it in the usual spot. colours are all similar.
inthe case of a S2 33 and 34 the smart entry system will foul the alarm if tied in at that point.
Edited by Chris Rogers
  • 8 months later...
WOOHOO this is so helpful, hey its to the right of your RIGHT foot, I got confused for a little there!
Its the loom that continues back under the carpet along the right side of the car :)
I'm not sure this is completely the same problem, but I have an alarm installed that triggers on both doors which are on separate circuits, but the interior light no longer turns on when the passenger side door is opened. My car originally had the factory keyless entry. I'm guessing it's probably a bad idea to brigde the two door wires down at the kick panel. Is there possibly any other way I can overcome this problem?
Was thinking maybe I need to link the interior light circuit to the passenger door switch via a diode, but I have no idea which wire the interior light trigger is.
Any help here would be appreciated. I don't really want to take it back to the installer they were quite rough with my interior trim after commenting how 'Nice & clean' my interior was (GT AUTOSOUND, DON'T GO THERE! If you truely value your car).
Edited by JazzaR33
I'm not sure this is completely the same problem, but I have an alarm installed that triggers on both doors which are on separate circuits, but the interior light no longer turns on when the passenger side door is opened. I'm guessing it's probably a bad idea to brigde the two door wires down at the kick panel. Is there possibly any other way I can overcome this problem?
are you sure the alarm works on bith doors?
bridging the wires will only make the lights on buzzer show on both doors not jst the drivers one.
Yeah pretty sure it works, confusing I know, but that's the way it's working at the moment. Not sure if it had anything to do with the factory central locking system as both the door wires did go to that. It has been removed so I'm thinking that's the reason.
  • 1 month later...
This has probly been solved i havnt read through the thread, but i made this a while ago when i disconected mine, Its a bit dodgey but its easy to do if you can make sense of it :P
http://www.boostcruising.com/forums/index....howtopic=167222
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
