Just been thinking recently... Do all of you think it is worth modifying a gtst when for the extra money spent you can but a gtr? not speaking about small mods but getting a gtst into the 12's do you think it is worth it? for that money you could almost get a gtr and have better interior, exterior and all the other associated goodies..
https://www.sau.com.au/forums/topic/11742-modding-gtst/
If i had 50K i would be buying a gtr asap! Nah i am thinking if it is worth spending like 15,000 over the next couple of years on my gtst or only buying my gtst bolt-on mods like an intercooler which i can take off and sell if i decide to buy a gtr or just take them off the gtst and sell it stock and put them on the gtr.
https://www.sau.com.au/forums/topic/11742-modding-gtst/#findComment-205155
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
