hmmm
yeah l still need them
or if you dont want to seperate l will consider the whole strut.
anyone out there with stuffed struts??? surely theres one leaking somewhere :)
Edited by OPtimus Prime
https://www.sau.com.au/forums/topic/117436-strut-tops/#findComment-2180547
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
